radiator cap?
Old Oct 10, 2004 | 08:05 PM
mickey513's Avatar
Default radiator cap?
Is the radiator cap 13lb or 16lb of pressure for a 94 Integra???? I pick up a cap and the thing said 13lbs....i thought it was 16????
Old Oct 10, 2004 | 08:19 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: radiator cap? (mickey513)
Sounds a little low, I believe stock is 1.1 bar, or about 15.x psi.
Old Oct 10, 2004 | 08:23 PM
mr.beeks's Avatar
Default Re: radiator cap? (PatrickGSR94)
better off with a 7lb car runs cooler......
Old Oct 10, 2004 | 09:58 PM
mickey513's Avatar
Default Re: radiator cap? (mr.beeks)
7lb????? I don't think so..
Old Oct 11, 2004 | 06:51 AM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.beeks &raquo;</TD></TR><TR><TD CLASS="quote">better off with a 7lb car runs cooler......</TD></TR></TABLE>
Are you referring to the radiator cap? The higher the pressure rating on the cap, the higher pressure the cooling system can reach. The higher the pressure, the higher the boiling point. Boiling is what you DO NOT want your coolant to do, as it will create all kinds of bubbles and air pockets, which could lead to a blown headgasket if any of that air gets caught in the water pump. Raising the pressure helps keep the coolant from boiling so it can more effectively carry the heat away from the engine.
Most of the JDM aftermarket caps like Mugen and Spoon are rated at 1.3 bar, or around 19 psi.
*edit* I think 1.1 bar is right at 16 psi, so the 16 psi cap would be the stock-rating replacement. I would not recommend going lower than 16 psi.
soon2bdropped
Oct 17, 2007 10:10 AM
prelude_93vtec
Jul 9, 2007 06:43 PM
Chuethou_b18c5
May 8, 2006 06:17 PM
92SiB18C1
Apr 9, 2003 06:40 AM
TenaciousC
Aug 19, 2002 05:28 PM
