vss problem need help
Old Oct 8, 2004 | 08:22 AM
B18civic5g's Avatar
Default vss problem need help
i have a code 17(vss), on a p72 ecu. i replaced the vss with a new one. Same problem, replace the plug that goes in too the vss too still no luck?
i want vtec!!!!
Old Oct 8, 2004 | 09:02 AM
dthrone's Avatar
Default Re: vss problem need help (B16civic4g)
help this boy! I would go nutz with no vtec!!!
Old Oct 8, 2004 | 01:10 PM
hybrid_vtec's Avatar
Default Re: vss problem need help (ANOTHER_JDM_EG6)
I am having the same problem!
bump for answer!
Old Oct 8, 2004 | 01:52 PM
dthrone's Avatar
Default Re: vss problem need help (hybrid_vtec)
where is all the "know it alls"??
Old Oct 8, 2004 | 03:07 PM
bussmancd7's Avatar
bump for the vss
Old Oct 8, 2004 | 03:35 PM
dustrag's Avatar
Default Re: vss problem need help (bussmancd7)
some 1 help this kid
Old Oct 8, 2004 | 06:40 PM
dustrag's Avatar
bump
Old Oct 10, 2004 | 01:28 PM
FastKTJ's Avatar
Do a search I think I've seen something around about a screw in the back of the cluster that could be lose. I'll see if I can find it for you guys
Old Oct 10, 2004 | 06:49 PM
B18civic5g's Avatar
Default Re: vss problem need help (FastKTJ)
thanks
Old Oct 12, 2004 | 10:09 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FastKTJ &raquo;</TD></TR><TR><TD CLASS="quote">Do a search I think I've seen something around about a screw in the back of the cluster that could be lose. I'll see if I can find it for you guys </TD></TR></TABLE>
Old Oct 12, 2004 | 06:38 PM
Xsi's Avatar
Xsi
Try resetting the ECU first
Old Oct 13, 2004 | 09:56 AM
Default Re: (Xsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xsi &raquo;</TD></TR><TR><TD CLASS="quote">Try resetting the ECU first </TD></TR></TABLE>
Been done!
I changed trannies after breaking my last tranny! I shattered the diff and the VSS gear went with it! So I used the one that came with my new tranny and since then my speedommeter doesn't work!
Old Oct 13, 2004 | 04:20 PM
B18civic5g's Avatar
Default Re: (hybrid_vtec)
Thanks will try
Old Oct 14, 2004 | 10:06 AM
Default Re: (B16civic4g)
My speedometer still doesn't work!
Old Oct 14, 2004 | 11:10 AM
artifex's Avatar
say it
pull out the new vss gear and check it for any damage/anything that looks funny. just something to check... blowing a transmission shouldn't adversely affect the guage cluster, but stranger things have happened...
still, check your current vss gear for any tooth wear/marks/anything out of the ordinary... might be that the vss gear isn't aligning correctly with the gear on the differential, causing it to not register any change in speed. i would think you would hear some noise if this was the case, however.
still, its a place to start.
Old Oct 15, 2004 | 10:08 AM
Default Re: (artifex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by artifex &raquo;</TD></TR><TR><TD CLASS="quote">pull out the new vss gear and check it for any damage/anything that looks funny. just something to check... blowing a transmission shouldn't adversely affect the guage cluster, but stranger things have happened...
still, its a place to start. </TD></TR></TABLE>
Thanx already done that though! Anyone else?
Old Oct 15, 2004 | 12:21 PM
dustrag's Avatar
PLEASE HELP
Old Oct 16, 2004 | 11:34 AM
Default Re: (dustrag)
bump for help!
Old Oct 16, 2004 | 01:43 PM
B18civic5g's Avatar
i need a hatch
Old Oct 18, 2004 | 10:53 AM
dustrag's Avatar
SINCE YOU BROKE YOUR RADIATOR
Old Oct 22, 2004 | 05:09 AM
artifex's Avatar
say it
check fuse no. 15 (7.5 amp) in the under-dash fuse box.
Old Oct 22, 2004 | 06:34 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by artifex &raquo;</TD></TR><TR><TD CLASS="quote">check fuse no. 15 (7.5 amp) in the under-dash fuse box.
I have already done that too, however there is supposed to be a relay in the circuit path too, but I dont know where it is!
Old Oct 22, 2004 | 06:57 AM
artifex's Avatar
say it
from the helms:
check for continuity on the black wire - connect positive lead from voltmeter to black wire that goes into the harness that plugs into the vss; connect negative lead from voltmeter to body ground. if there is no continuity, there's a problem with the black wire somewhere along the way.
if there IS continuity, check the black/yellow wire in the harness for voltage. to do this, connect the positive lead of your voltmeter to the black/yellow wire, and the negative lead to a body ground. turn the ignition switch ON. if you don't read voltage, there's a problem with this wire.
if you DO read voltage in the black/yellow line, test the blue/white wire for voltage: connect the positive lead of your voltmeter to the blue/white wire inside the clip that you plug into your VSS. connect the negative lead of your voltmeter to a body ground. turn the ignition switch ON. It should read about 5 V more than the black/yellow line. if it doesn't, there's a probelm with this wire.
if it does read approximately 5V more than the black/yellow wire, test the VSS. since you already replaced the VSS, we'll skip that part and move on to the gauge cluster.
to test the speedometer, put the front end of your vehicle up on jack stands. put the transmission in neutral. pull your gauge cluster out of your dashboard, disconnect the 16 point connector from the gauge assembly. turn the ignition switch ON. connect the positive lead of your voltmeter to the ORANGE wire in the connector. connect the negative lead to a body ground. have a friend hold one wheel (stop it from turning) while another slowly rotates the other. if the voltage pulses (oscillates) your speedometer is the source of the problem and needs to be replaced.
if you do not read pulsing voltage, the helms says "Repair open in the ORN and BLU/WHT wire between the VSS and the speedo-meter."
that's all i got for ya. good luck.
Old Oct 22, 2004 | 10:34 AM
dustrag's Avatar
DAVE THAT MIGHT HELP
Old Oct 28, 2004 | 06:47 PM
B18civic5g's Avatar
thanks!
stpacura
Lighting
Sep 12, 2008 10:46 AM
h22_crx
Jul 16, 2008 07:07 PM
tweakit
12
Aug 9, 2004 03:39 AM
LukeDanger
Feb 23, 2004 04:09 AM
