I need help asap!!!!!!!!!!
Old Nov 17, 2004 | 11:32 AM
dc9turbo's Avatar
Default I need help asap!!!!!!!!!!
i just bought a 96 ls bone stock and it is runin really really lean, also it sometimes stutters at street lights and the rpm drop, and i have a manit. reqd. light. was wondering what could that light refer to and how to find out the cause of those two problems. please help!
thanks,
manny
Old Nov 17, 2004 | 11:53 AM
Gen_2_Garvin's Avatar
Default Re: I need help asap!!!!!!!!!! (dc9turbo)
Have you done a compression test on your car?
Old Nov 17, 2004 | 11:54 AM
Default Re: I need help asap!!!!!!!!!! (Gen_2_Garvin)
Make sure all of your plugs are getting spark too cause if your running on only 3 that would explain alot
Old Nov 17, 2004 | 02:44 PM
dc9turbo's Avatar
how much is a compression test?? and could it be oil in the distributor??
Old Nov 18, 2004 | 06:22 AM
95lstegman's Avatar
first off, the maint. requ.'d light means nothing except a friendly reminder from honda to change your oil. it can be reset by reaching just past the driver's kickpanel for a small, blue button. push it for a few seconds, and the light won't come on for i think 7500 more miles.
second, are you absolutely sure it's running lean and not rich? it is way more likely to run rich than lean. but tell me, when you're driving, is there a great loss in power? also, when at a stop light, is it always sputtering and rpm dropping, or only sometimes? just give me a little more info so i can help you out.
a compression tester is about $20 at autozone, and is one of the more important tools in a home mechanic's garage; no, i've never heard of oil in the distributor.
Modified by 95lstegman at 11:20 AM 11/18/2004
Modified by 95lstegman at 1:29 PM 11/18/2004
Old Nov 18, 2004 | 06:25 AM
nolexforever's Avatar
after you check all the usual stuff first, ask when was the fuel filter last replaced?
Old Nov 18, 2004 | 10:03 AM
x00gsr's Avatar
Check the small stuff first. Adjust the idle see if that works first.
Old Nov 22, 2004 | 07:04 AM
dc9turbo's Avatar
Default Re: I need help asap!!!!!!!!!! (95lstegman)
only sometimes at lights, and my a/f is telling me lean plus the spark plugs are white
Old Nov 22, 2004 | 12:11 PM
95lstegman's Avatar
Default Re: I need help asap!!!!!!!!!! (nolex7)
i agree with nolex7, i bet it's the fuel filter. it's very likely the culprit. if that's not it, you'll probably just need a good cleaning of the injectors.
Double Agent
Mar 24, 2009 02:46 PM
kid_honda
Aug 26, 2008 05:29 PM
chiheat
Honda S2000
Jan 13, 2006 10:54 AM
IloveNewt
Mar 2, 2003 10:13 AM
TypeR01-424
Jul 5, 2001 12:41 PM
