what is the differnce?? (transmission)
Old Nov 15, 2004 | 04:28 PM
eg64u's Avatar
Default what is the differnce?? (transmission)
I know the gsr is different then the type r but what else is the differences from the gsr/sib16/ls/type r.... etc.. transmissions that is.. i heard that the b16 and type r are the same trans but not positive.
let me know
thanks
Old Nov 15, 2004 | 04:33 PM
..::91TEG-G2::..'s Avatar
Default Re: what is the differnce?? (eg64u)
b16 and itr trans have the same gear ratio but different final drives i believe. not exactly sure.
ls tranny's are the longest geared trans. if the bunch, not really made for performance and bad for the track.
and not sure bout the gsr trans either. might be close to b16 tranny
and not exactly sure bout the rest
Old Nov 15, 2004 | 07:53 PM
eg64u's Avatar
cool thanks for a reply
Old Nov 15, 2004 | 08:44 PM
SiR Inspired ED7's Avatar
all i got to say is, my b16a is running like **** with my A1 tranny
even though i'm stock...
all i got is I/H/E, p72
Old Nov 15, 2004 | 09:14 PM
LSvtec03's Avatar
Default Re: what is the differnce?? (93 Da 16a)
b16 and type r are the shortest-geared, followed by the gsr, and the stupid ls (God, i hate that tranny).
type r has a 4.4 fd (us) and 4.785 fd (jdmland) and limited slip diff.
controversially type Rs have stronger synchros because they are "dual cone." do i know what that means? no. do i know if it's true or not? no.
some b16s have a 4.4, some have a 4.266 fds
ls has a 4.266 fd
summation:
ls trannies suck a nut, and the rest get
Old Nov 15, 2004 | 09:28 PM
Default Re: what is the differnce?? (LSvtec03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">ls trannies suck a nut </TD></TR></TABLE>
Old Nov 16, 2004 | 08:21 AM
eg64u's Avatar
cool thanks for the replys.. i thought thats how it was.. but not to positive .. but i still want to make sure
Old Nov 16, 2004 | 09:28 AM
purplegsr's Avatar
Default Re:
Here are all of the gear ratios, I think some sources have debateable info, but it's close enough to make a decision on which tranny you prefer
http://www.allmotorhonda.com/t...s.htm
As you can see from this chart, not every b16 tranny has the same ratios as an ITR tranny, sometimes they share ratios in 3 gears, and sometimes they are slightly different across the board. However, they are pretty similar and will probably exhibit the best acceleration, with the lowest top speed due to gearing. Getting a GSR tranny, or a b16/itr with a LS 5th gear is an option if you are concerned about running close to 4500rpm while cruising at 80mph.
crivera330
Transmission & Drivetrain
Nov 14, 2010 11:11 AM
twentyhurtz
Mar 11, 2009 05:09 AM
lubmyinteg
Aug 28, 2007 10:59 PM
HondaMan73
Oct 27, 2004 01:54 PM
