windows on integra??
Old Nov 17, 2004 | 09:10 PM
stock_cx's Avatar
Default windows on integra??
well, my window isn't broken or anything but the driver window just moves a lot slower then the rest. it seems to struggle going up and down. Is there a way to fix this???
car is a 96 gsr sedan
thanks
Old Nov 17, 2004 | 09:30 PM
sir boostalot's Avatar
Default Re: windows on integra?? (stock_cx)
i had the same problem and i didn't do **** to fix it, i just kept toying with it. eventually it went back to normal (in a couple of days). not the way to handle this situation though. window started trippin on rainy days.
Old Nov 17, 2004 | 09:33 PM
stock_cx's Avatar
Default Re: windows on integra?? (ssboost)
i had the problem once before on the 96 civic, pretty soon it stop working most of the teeth were gone. new window regulator cost about $60
would this happen to my integra
Old Nov 17, 2004 | 09:53 PM
virusiidx's Avatar
maybe the motor just needs to be oiled, try taking apart the door panels
Old Nov 17, 2004 | 10:49 PM
stock_cx's Avatar
Default Re: (virusiidx)
the window is not a common problem for the integra or anything is it.
i know for the 96 civic ex it seems to be a commom problem.
Old Nov 17, 2004 | 10:54 PM
sabotage7's Avatar
my drivers side window was doing that.....i lubed up the tracks and that seemed to help for a little......it eventually went away and was fine......but now my passenger side window is doing it! its like they just decided to trade! lol......try lubing up the tracks w/some air tool oil and see if that helps, make sure the tracks are clean first! goodluck!
Old Nov 18, 2004 | 01:30 AM
4g4drb17's Avatar
Default Re: windows on integra?? (sabotage7)
a hot girl that works on her own car wow thats hot
if you dont know what i'm talking about click sabotage7's link and go to page 3
Old Nov 18, 2004 | 01:47 AM
Sack Master's Avatar
Default Re: windows on integra?? (4g4drb17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g4drb17 &raquo;</TD></TR><TR><TD CLASS="quote">a hot girl that works on her own car wow thats hot
Old Nov 18, 2004 | 06:58 AM
be.twenty's Avatar
holy leg humpers.
anyways, there's an article on team-integra.net that describes the problem and instructs on how to fix it.
Old Nov 18, 2004 | 07:44 AM
llsugarll's Avatar
Did you ever fix your problem? I'd love to do anything to prevent from going to replace the motor in my driver side window...but its REALLY bad. I have to push down really hard to get that window to get going anywhere. = /
Old Nov 18, 2004 | 08:53 AM
integ6657's Avatar
Default Re: (llsugarll)
Regular problem at my dealership. We just usually take a bottle of spray silicon spray the window channels. Use the little tube and spray very well where the window meets the door. This usually does very well.
Old Nov 18, 2004 | 09:30 AM
sabotage7's Avatar
Default Re:
here's that article that shogun-dc2 is talking about! http://www.team-integra.net/se...D=596
Old Nov 18, 2004 | 09:40 AM
turboteg96's Avatar
Default Re: Re: (sabotage7)
I was having somewhat the same problem and the spray would'nt fix it. Once day it got so bad the window jumped out of the track.
Soooo, I took the door panel off, there's an alignment bolt somewhere in the midle of the door. I loosend it and moved it over a bit to one side and Wazamm, my window has worked perfect since. Only thing is its a bit slower..
Oh Ya Way to go on being hot and working on your car....
dingobat
Oct 9, 2008 09:56 AM
iBear
Sep 25, 2006 11:33 PM
WhiteOnRice
Jun 23, 2006 04:15 PM
KEVlN
11
Nov 11, 2005 08:36 PM
BOLO40
May 19, 2004 09:15 PM
