ignition problem?
Old Nov 15, 2004 | 02:22 PM
94PearlWhiteGsr's Avatar
Default ignition problem?
When I turn the key into ignition, it's silent and takes a while before it cranks. I would say it takes about 5-6 seconds then the engine will turnover and start up fine. Can anyone tell me why this is hapening? Thanks.
Old Nov 15, 2004 | 03:41 PM
marsbike's Avatar
From: Salt Lake City, Chicago at heart, UT or IL, USA
Default Re: ignition problem? (GsrIntegra94)
I'd like to know too. I had it happen to me on sunday!
Old Nov 15, 2004 | 06:21 PM
marsbike's Avatar
Default Re: ignition problem? (marsbike)
bump for an answer and a little piece of mind?
Old Nov 15, 2004 | 06:22 PM
NightRiderS2K's Avatar
In-N-Out Burger
Do you hear your fuel pump prime right away?
Old Nov 15, 2004 | 07:38 PM
marsbike's Avatar
Default Re: ignition problem? (NightRider-gsR)
sometimes yes, sometimes no
Old Nov 16, 2004 | 06:25 AM
marsbike's Avatar
please help someone!
Old Nov 16, 2004 | 01:10 PM
In-N-Out Burger
Where do any of your cars idle after it does start up.
So far, to me it sounds like a fuel up that's headed in the failing direction.
Another thought. It could also be a faulty main relay. The relay definitely controls the fuel delivery so you guys might also want to follow up on that.
Old Nov 16, 2004 | 04:18 PM
marsbike's Avatar
my cold RPM's are around 1500, then drop to 7-800. IT's pretty normal. Sometimes it happens in the morning, sometimes it doesn't it's quite odd. If I release the clutch and push it slightly sideways as I'm starting the car instead of STRAIGHT down, it'll catch and fire right up. The fuel pump clicks on right away, so I doubt it's that.
Old Nov 16, 2004 | 04:19 PM
marsbike's Avatar
Sorry to hijack this thread, but I want an answer.
Broke_not_built
Aug 22, 2011 10:40 AM
White98LS
Jul 14, 2007 07:46 AM
spettinger
May 25, 2005 11:46 AM
lazykiwi
Jan 16, 2005 08:44 AM
2camsaam
Jul 14, 2003 09:09 AM
