Interior Wiring
Old Nov 18, 2004 | 07:03 AM
2ndgentegracer's Avatar
Default Interior Wiring
I bought another Integra yesterday, its a 91 GS, I think its Captiva Blue (not sure). The previous owner had some gauges and a neon hooked up with no radio. Some of the interior lights don't come on, and some of them are dim. I'm thinking there might be something wrong in the wiring, and I haven't checked my Chilton yet. If anyone can post up a wiring diagram of the dash, that would be great. Thanks in advance. Peace
edit: Last night when I tried to wire up my stereo, I swapped out the harness, and when I went to turn on the radio it came on, then died, and the clock flickered, and some lights in the cluster flickered too.
Old Nov 19, 2004 | 08:53 AM
Default Re: Interior Wiring (2ndgentegracer)
Bump I need to know if the wires for my gauge pod and my neon under the dash would be grounding out the radio power.
Old Nov 19, 2004 | 08:57 AM
g2teg27's Avatar
check your radio fuse. the reason i say this is that i had a very similar problem doing a radio install in a DA. i redid the harness a few times, and eventually assumed it wasn't getting a proper ground. if that fuse keeps blowing, that's more than likely your problem.
also, take a look at WHERE these gauges, neons, etc are actually drawing their power. i'd physically trace the wire from the item (gauge, neon, etc) to the point where it's drawing its power and ground. alot of times people will rush installs and power to many things off of one point, or more likely in your case, ground it all in the same place.
Old Nov 20, 2004 | 10:10 PM
Default Re: Interior Wiring (g2teg27)
Yea it was the fuse. I checked it today then replaced it, it works now. Thanks.
Boostn B20
Sep 18, 2008 04:42 PM
usdm.ehtu
Mar 17, 2007 07:54 PM
Duo57
Aug 12, 2004 07:06 AM
racecarpete
Apr 23, 2003 07:00 AM
