TDC sensor? please help!
Old Nov 17, 2004 | 02:30 PM
calvinone67's Avatar
Default TDC sensor? please help!
Hello everyone. okay let me cut to the chase. I just bought a 1989 Acura Integra LS hatch w/129k 5spd with new timing belts, waterpump, new tires and clutch for only 1500.
okay, before i left the private dealers house. i test drove it.. man it was running VERY GOOD!..UNTIL i was driving home.... the "check engine"light came on.. i soon found out that it was the TDC sensor? honstly. i dont know what that is.. and how much would it cost me. to get that damn light out. so i can pass smog.
-calvin-
Old Nov 17, 2004 | 03:41 PM
Default Re: TDC sensor? please help! (calvinone67)
any one??? TTT
Old Nov 18, 2004 | 05:02 AM
JimBlake's Avatar
Maybe '89 isn't much different than my '95???
TDC sensor is one of the toothed-wheel sensors down inside the base of the distributor. Look for wiring problems - loose, corroded, connections.
Take off the distributor cap, rotor, look around in there. Red dust is bad (bearing). Broken pieces are worse. I guess you can't buy the sensors, you have to buy a distributor.
Old Nov 18, 2004 | 05:24 AM
HONDA RR's Avatar
Default Re: TDC sensor? please help! (JimBlake)
Your tdc timing or ignition timing might be off have it checked by a mechanic or buy a timing gun and adjust it your self.
Old Nov 18, 2004 | 05:47 AM
mr.beeks's Avatar
basically in a nutshell
most of us here dont have a 1st gen integra.
but if is the same as the the second the sensor is located in the distributor
so check another distributor that will solve the problem
Old Nov 19, 2004 | 02:38 PM
Default Re: TDC sensor? please help! (mr.beeks)
cool thanks! guys. well what i did was.i got a used one from Pick-n-pull for only 50$ and it worked. thanks. for the help!!!
Derrick_12341
Jul 26, 2018 07:15 AM
oldman64
Nov 4, 2017 07:50 PM
philipkrotch
Jan 23, 2003 10:40 AM
Wide Open Throttle
May 29, 2002 03:29 PM
