sound system help..
Old Nov 16, 2004 | 04:30 PM
ckehl13's Avatar
Default sound system help..
hey, i'm a relatively new integra owner and the car i bought has the factory stereo, speakers, and everything. i really want to upgrade it all with new speakers, amp, maybe even a sub or two and i wanted to find out what speakers work well with integras and i figured why not ask the integra community first hand?
any help is appreciated. i'm only 16 so anything fairly inexpensive would help a lot. something with a lot of quality for not like a billion dollars thanks everyone!
just for reference, i've got a 2000 integra ls. voltage blue w/ grey/black standard interior (if possible have something that matches) i also plan on getting new tenzo seats, a momo wheel, and some blue neon to flood out of the spot where the pedals are. all color coordinating so any help to match would be excellent! THANKS SO MUCH!
p.s. i've got a pretty loud exhaust system so it would have to be pretty loud. it's a thermal exhaust system if that helps? i'm not really sure on the specs.
Old Nov 16, 2004 | 05:19 PM
qcktegls's Avatar
Default Re: sound system help.. (ckehl13)
i have an alpine head unit with two 12 inch infinity kappa perfects. thats right 3000 wattss of power. but neways if you want good sound. put a sub in and go with polk audio speakers. they are excellent. havent found better for speakers. gl
Old Nov 16, 2004 | 05:20 PM
lv6l's Avatar
for the rear go with 6.5" coaxial speakers, front 6.5" component set, the front wont fit right on, all you need is take off the black plastic speaker holder out and use any screw to screw in the new speakers, for quality wise, i recommend FOCAL ACCESS, i can get them 200 for front and about 150 for rear, if you still think thats a lil high on the pricy side, trust me, they are worth it so much. if you want something cheaper than go with infinity kappa, those are a lot cheaper,price range about 60 for rear and 140 or less for front. they sound just as nice as the FOCAL, any other brands i have tried and will not compare to the ones i've recommended. amps and subs its up to you, i do have an Alphasonik amp for sale if you intrested, i'm selling it for 250. it has aprox. 2000 watt. and is made for subs only. i've delt with a lot of brands out there over the years and my opinion alphasonik makes one of the best and affordable amps.
Old Nov 16, 2004 | 05:28 PM
.brian.'s Avatar
Default Re: (lv6l)
https://honda-tech.com/zeroforum?id=27 You might get more response there.
Old Nov 16, 2004 | 07:49 PM
mr.beeks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ckehl13 &raquo;</TD></TR><TR><TD CLASS="quote">
p.s. i've got a pretty loud exhaust system so it would have to be pretty loud. it's a thermal exhaust system if that helps? i'm not really sure on the specs.</TD></TR></TABLE>
those things will only attrack thieves and cops so think about it
if you really want to be cool with us here that mentality will have to stop..
dont make your car look like a christmas tree.
buy what you really need...
get a good set of 6.5 all around a good light bass box so you dont add any xtra
weight to your ride.
Old Nov 16, 2004 | 08:25 PM
marsbike's Avatar
From: Salt Lake City, Chicago at heart, UT or IL, USA
Default Re: sound system help.. (mr.beeks)
Right now I'm using an Alpine CDA 9835 head unit, which is badass, MB quart refrence series for the front, and MB quart coax for the rear, a kicker 1200 watt amp paired up to a pair of Alpine Type R 12" subs, and a kicker KX 850 powering the internal speakers, plus a cap 5 capasitor. I personaly didn't match any of my stuff to my interior, because I like going stealth. Can't tell what I'm rockin unless my car's bumpin.
Old Nov 16, 2004 | 10:23 PM
b-power's Avatar
alpine heaunit, 6.5 infinity kappas, 1 badass 10" or 12" sub and a helluva amp . thats all you need
Old Nov 16, 2004 | 10:56 PM
fried's Avatar
pioneer have blue speakers i think?
basically, if u want something that sounds good, go listen to some speakers, and see what u like.
brandobot89
Audio / Security / Video
Jul 7, 2008 09:38 PM
hans stoner
May 19, 2008 08:28 AM
ckehl13
Jan 5, 2005 05:57 PM
ckehl13
Dec 4, 2004 07:22 AM
