Weird Problem with Acceleration?
Old Nov 15, 2004 | 04:40 PM
Ls InTeGrA RaCeR's Avatar
Default Weird Problem with Acceleration?
My car is stuttering inbetween 4k and 5k rpm when I floor it (and this is only in 2nd gear and a little in 3rd). I just recently Turbo'd my Ls but I had this problem before that. I replaced the injectors already. What could be causing this problem? Please give me some insight. Thanks.
Old Nov 15, 2004 | 05:06 PM
gsrboi80's Avatar
Default Re: Weird Problem with Acceleration? (Ls InTeGrA RaCeR)
either spark or gas. How your cap, rotor, plugs, wires. Fuel filter? Mabey if its when you floor it only it could be a throttle cable problem.
Old Nov 15, 2004 | 05:55 PM
Default Re: Weird Problem with Acceleration? (gsrboi80)
shouldn't be anything wrong like that.......only 65,000 miles on the car?
Old Nov 15, 2004 | 05:59 PM
Oleg's Avatar
can you please tell me how much did you end up spending on turbo, and what did you get. I will really apprishiate the answer.
Old Nov 15, 2004 | 06:12 PM
InTeGrA B18b1's Avatar
Default Re: Weird Problem with Acceleration? (Oleg)
regap your plugs its probably losing spark. if it stil does it gap it even smaller.
Old Nov 15, 2004 | 06:32 PM
To Answer your question, I got a Full Greddy Kit with Greddy Type S Blow off Valve, Front Mount, Piping, Manifold, and Injectors all for 2G's
Old Nov 15, 2004 | 06:33 PM
lsboyb18's Avatar
my car does the same thing at around 2-3k in 2nd and 3rd gear...its so frustrating. ive just changed my plugs and wires but still the same. can it be my fuel pump or fuel filter?
Old Nov 16, 2004 | 04:40 AM
gsrboi80's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls InTeGrA RaCeR &raquo;</TD></TR><TR><TD CLASS="quote">shouldn't be anything wrong like that.......only 65,000 miles on the car?</TD></TR></TABLE> It has to be somthing like that these kinda things are what will cause your problem. My car has 65000 also and Ive replaced all that **** already preventative maintence
Old Nov 16, 2004 | 09:29 AM
WRTEG's Avatar
check your distributar and plugs, wires
Old Nov 16, 2004 | 05:17 PM
Default Re: Weird Problem with Acceleration? (94IntegraNL)
I checked the plugs and wires...no prob there, I'm going to check the distributer tommorrow.
CPreston
Feb 1, 2011 11:20 AM
superdat1
May 1, 2008 10:20 PM
1dumbscreenname
Jul 17, 2003 01:15 PM
Hapa88
Apr 23, 2003 10:45 AM
mattymatt
Jun 28, 2001 12:50 PM
