head swap problem- help please
Old Nov 17, 2004 | 07:44 PM
95gsrturbo's Avatar
Default head swap problem- help please
so i just got it together and it wont start, going crazy! 4 days now!
ok so spark and fuel are there-- checked compression -- it was 0 ZERO zilch!
forgot to reset valve lash-- all valves waaaay open or waaay closed-
so not that this is set i have another issue
I am finding oil where head meets block-- car still not started yet- just turning it over with no plugs or wires on to test compression, no idea where its coming from - if you stick your hand under the exhaust manifold and turbo its a clean line
yes we checked to make sure dowel pins were in - both on front side of motor
all gaskets were check.... no idea whre the oil is coming from?????
ive been told to check the distributer, and vtec sol.
any other ideas--- can it be a bad headgasket from honda?
Old Nov 17, 2004 | 09:30 PM
TeggyNY's Avatar
Default Re: head swap problem- help please (95gsrturbo)
Yea it could be good luck
Old Nov 18, 2004 | 05:38 AM
95gsrturbo's Avatar
Default Re: head swap problem- help please (TeggyNY)
^^ yeah it could be WHAT
Old Nov 18, 2004 | 07:23 AM
95gsrturbo's Avatar
please guys, i really need to find out if i could be getting the oil from between blcok and head or just from elsewhere you think
black teg
Dec 4, 2013 10:29 AM
ss30378
Oct 14, 2013 02:57 PM
jlopez88
May 14, 2008 07:23 PM
pchris52
Apr 3, 2007 05:54 PM
95gsrturbo
Nov 18, 2004 08:51 AM
