Bouncing Tach
Old Nov 16, 2004 | 04:57 AM
Mike1486's Avatar
Default Bouncing Tach
My teg as always done this, but now its been doing it more and more recently. When I come to a stop, and I have my foot on the brake and idling, my RPMs will go just under 1000, but then it'll bounce from 800 to 600 and the car vibrates alot when this happens. Now it may not always be idling at 800 it sometimes is a bit higher or lower, but what im concerned about is the bouncing tach and the vibrations. Any suggestions?
Old Nov 16, 2004 | 07:31 AM
gsrboi80's Avatar
Default Re: Bouncing Tach (Mike1486)
My car does the same thing so bump for us
Old Nov 16, 2004 | 08:47 AM
Mike1486's Avatar
Default Re: Bouncing Tach (gsrboi80)
have u found a way to correct the problem or diagnosed it at all?
Old Nov 17, 2004 | 01:13 AM
gsrboi80's Avatar
no im in the same boat you are. Not a clue as to what it is
Old Nov 17, 2004 | 04:43 AM
JimBlake's Avatar
Clean your IACV. Get new spark plugs if they're old. Look at them if they're newer. Clean or replace spark plug wires, distrinutor cap & rotor. That rules out the simple tune-up stuff before you start worrying about anything serious.
Old Nov 17, 2004 | 09:44 AM
Mike1486's Avatar
Default Re: Bouncing Tach (JimBlake)
replaced my whole distributor plugs and wires not even 3-4 months ago. Could it just be idle hoses? Cause it only happens with my foot on the gas and the car in drive. If i put it in nuetral... it doesnt happen.
Old Nov 17, 2004 | 10:00 AM
crawdad689's Avatar
I've heard it could be vacuum lines?? Don't take my word for it, I'm a n00b
miguey310
Jun 2, 2009 12:29 AM
KingRichard
Jan 15, 2008 04:15 PM
force-fed
May 9, 2006 05:05 PM
JDM-EJ698
May 5, 2006 02:35 PM
Downz
Apr 24, 2006 11:55 AM
