Spring squeak
Old Nov 17, 2004 | 03:39 PM
Racermech's Avatar
Default Spring squeak
Hey guys, I have a set of lowering spring that i got a few years back, i cant even remember the name of them. But ever since the day i put them in the have squeaked. I tried to lube them, grease them, finally i took some wire loom and feed it around the dead coils and that stopped the squeak. But it is kind of a bad way of doing it. Any ideas on how i can stop the squeak, without the loom in there??
Old Nov 17, 2004 | 03:45 PM
RidinStock's Avatar
Default Re: Spring squeak (Racermech)
I have a nice squeak from my rear suspension (although its coilovers) so bump for an answer. Could it be the bushings?
Old Nov 17, 2004 | 04:57 PM
bseries52's Avatar
Default Re: Spring squeak (RidinStock)
It could be bushings. See how much it would cost for a whole new set of bushings. Otherwise... Idk.
Old Nov 18, 2004 | 05:04 AM
JimBlake's Avatar
Try spraying some silicone in the bushings, one by one. It won't fix it for long, but it'll tell you which one (or more) is making the noise. Then you can replace it or maybe grease it or something?
Old Nov 18, 2004 | 01:35 PM
RidinStock's Avatar
Default Re: Spring squeak (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Try spraying some silicone in the bushings, one by one. It won't fix it for long, but it'll tell you which one (or more) is making the noise. Then you can replace it or maybe grease it or something?</TD></TR></TABLE>
Yea... well my problem is just I'm too lazy to go buy a bushing kit and put it all in. Actually, I would have no idea where to start/what to do, but I'm sure I'll get around to it when I can't stand the sound anymore.
Old Nov 18, 2004 | 02:48 PM
Chris_Bye's Avatar
mine squeak cause the bushings...
Old Nov 18, 2004 | 03:15 PM
GSRRacer95's Avatar
I also have a squeak in my front end. Mine ended up being that the upper control arm bushings were shot. I invested in a pair of skunk2 upper arms.
Old Nov 18, 2004 | 04:37 PM
hatchinprogress's Avatar
Default Re: (GSRRacer95)
my squek is from coil overs
Old Nov 18, 2004 | 06:02 PM
2gturboteg's Avatar
Default Re: (hatchinprogress)
the reason that some cars start squeaking after you lower them, regardless of how old they are is because the bushings or ball joints over time have worn to the other height. now you changed the position static height of the suspension and now a part of the bushing or ball joint that never got used before is being worn. hence the noise. you can try to lube but part replacement is the best route in the end.
Old Nov 18, 2004 | 06:10 PM
gsrboi80's Avatar
Default Re: (2gturboteg)
So a poly bushing kit will solve the problem right?
Old Nov 20, 2004 | 08:01 PM
2gturboteg's Avatar
Default Re: (gsrboi80)
90 percent of the time it will. or you could just track down which bushing is creaking and just replace it. but more than likely the others will eventually make noise. either way its a lot of work.
Old Nov 20, 2004 | 08:29 PM
RidinStock's Avatar
I figured out what was squeaking! I was adjusting my suspension today and as I was messing around with the spring and coilover, I noticed an old rubber bushing that I'd never seen before. I guess it fell out of place, but it goes between the spring and the top. I have a picture but the batteries in the camera died so I will have to upload it another time, but I'll bet this is the main culprit for everyone.
JDM_Ej
Suspension & Brakes
51
May 3, 2012 12:00 PM
Jaybmoc
Suspension & Brakes
Jun 6, 2006 12:00 PM
tianporn
Suspension & Brakes
Jun 19, 2005 09:24 AM
MattG
Apr 29, 2003 08:47 PM
Benj
Nov 15, 2002 04:55 AM
