Code 43, fuel supply system
Old Nov 15, 2004 | 06:40 PM
cincispeedemon's Avatar
Default Code 43, fuel supply system
What all could cause this???
Old Nov 15, 2004 | 06:44 PM
ferio 95's Avatar
Default Re: Code 43, fuel supply system (cincispeedemon)
does your car start? if not its your fuel pump fuse or could be clogged injectors
Old Nov 16, 2004 | 08:34 PM
Default Re: Code 43, fuel supply system (ferio 95)
car starts fine, i thought about replacing the fuel filter to see if it helped
Old Nov 16, 2004 | 08:43 PM
mr.beeks's Avatar
did you mess around with the second thing that looks like
an fpr with a plastic covering it at the other end of the fuel rail.
it also has a screw that could cause this
Old Nov 16, 2004 | 08:47 PM
sillyboi's Avatar
Default Re: Code 43, fuel supply system (mr.beeks)
i got the same problem, but only when i take it near redline.. but when i shut off the motor and start it again the engine disappears..
Old Nov 22, 2004 | 12:47 PM
GSRCRXsi's Avatar
Default Re: Code 43, fuel supply system (sillyboi)
thats because the codes are stored in the ecu you wont see it agin til it throws the code again or you jump the connector to display the code.
Old Nov 22, 2004 | 05:51 PM
No i didn't, what should could I do?
95civic16
May 18, 2009 08:01 PM
mozzandherb
Dec 15, 2006 08:31 AM
str8JDMteggy
Sep 29, 2006 08:27 AM
Mr. 1582
Nov 8, 2003 04:23 PM
oO
Apr 10, 2003 07:03 AM
