axle help please!!!
Old Oct 12, 2012 | 11:54 AM
neonkid's Avatar
Default axle help please!!!
ok im pulling a trans and replacing the clutch in my buddys gsr and i know how to pop the axles out by hitting the control arm by the boot but it doesnt wanna break free does anyone else have any suggestions for me? i need to get this done asap!!!!
Old Oct 12, 2012 | 12:33 PM
jazzRS's Avatar
Default Re: axle help please!!!
um, wont pop free from where? it should slide out of the hub pretty easy and than you take a pry bar inbetween the axle and trans to pop it out there
Old Oct 12, 2012 | 12:34 PM
kyden's Avatar
rubber mallet to the end of the axle. or a block of wood and a hammer. at least that's what i think you're talking about.
Old Oct 12, 2012 | 01:32 PM
DeCePtEgRa's Avatar
Yah both sides should come out with ease as stated above should pop them out. Make sure you lube the splines when you install new ones will help for next time
Old Oct 12, 2012 | 01:51 PM
neonkid's Avatar
never mind guys but no i worded that wrong i couldnt remove the knuckle from the lca itself the axle slid out fine i had to take both of the knuckles off to get it out but i got thanks for the input anyway guys!
sirt_eg
Jun 11, 2007 03:02 AM
Bserieskiller
Suspension & Brakes
Feb 16, 2006 06:30 PM
PIC Performance
Dec 4, 2005 07:12 PM
bigdogc
Jul 19, 2005 04:37 PM
ill phil
May 15, 2003 06:27 PM
