having vtec problems!
Old Oct 23, 2012 | 05:34 PM
cmwalker's Avatar
Default having vtec problems!
i have a gsr block with a b16 head fresh rebuilt. just recently went for a tune and the car wasnt hitting vtec. set to engage at 5500 it would rev to about 6k. loose all power and barely climb past 7k. No Check engine light. i asked the tuner to disable vtec and it sound and did the exact thing.... so im thinking its an oil pressure problem i ran an external hose from the oil pressure switch whole to the head. now the car hits cut out and wont go past 5500 almost like a rev limit....
the b16 head was used on my lsv and must have overlooked the plug in the head... but why is this cutting out like a rev limit at 5500 right when vtec is trying to engage, is it possible it just needs a tune....anyone experience this?
Old Oct 25, 2012 | 07:33 AM
jazzRS's Avatar
Default Re: having vtec problems!
not sure why your car isnt revving up, but if your head was recently rebuilt id check for a missig dowel/o-ring under cam cap number 3
Old Oct 25, 2012 | 08:53 PM
el crapitan's Avatar
check your oil pressure. at idle, and at 3000 rpm. see if it's within spec
B18c1turboedEK
Jun 6, 2007 10:07 AM
yeungkaho
Mar 21, 2007 04:59 PM
bigmacks
Aug 25, 2005 02:08 PM
KillerBTeg
Jan 26, 2005 09:44 AM
f@sth@tch89
Feb 5, 2004 07:49 PM
