B-Series Fuel Pressure Regulator All the SAME?Swap QUESTION
Im doing a swap quick information JDM b16a into a EK
I recently bought a B16 fuel rail without the fuel pressure regulator, the guy told me my d series would work but not sure if its the same would it effect my performance? But if it doesnt what type and year car can i get the fuel pressure regulator?Any B series 90+++ integras is this statement true?
Re: B-Series Fuel Pressure Regulator All the SAME?Swap QUESTION
no you need a b series one!
What would happen if i dont use a VTEC one i have a none vtec on now but i havent test drove it yet due to a axle nut =[
it wont give you enough fuel pressure in vtec or even at any rpm because the ecu is not calibrated to use that fpr so it might run like **** lean or rich either which is bad for the motor.
Old Fart
Why not just get an aftermarket adjustable one...
http://www.andysautosport.com/acura/...e00000041.html
Or if on a budget...
http://www.andysautosport.com/acura/...trous_express/ 94
Aftermarket aem or nitrous express FPRs in california will not pass smog visual inspection, parts must have CARB (California Air Reasources Board) numbers.
If this is going into a track car then use them, if its a daily driver find a oem vtec b series FPR. The price you pay to live in california.
The five gas analyzer probe is put in the tailpipe of a car with similar required gas amounts and the car with the swap info is put in machine.
Mr.Callofduty2
07-13-2010 05:10 AM
