idle and timing problems help plzz
Old Oct 15, 2012 | 01:00 PM
jreed773's Avatar
Default idle and timing problems help plzz
i recently just did a head swap on my 90 integra we got everything together but when i fire it up it idles like **** we did have some problems getting the cam gears to line up but we worked that out im thinking the shitty idle is from improper valve adjustment can someone plz help me out or let me kno if i may have done something wrong with the timing or may have overlooked sumthing
Old Oct 15, 2012 | 03:20 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: idle and timing problems help plzz
Ok when you swap on a new head there many things that need to be done! i dont even know where to start! you may have already bent a valve.
Double check your cam gears are at tdc!
Did you make sure the crank gear was at bdc and aligned with the oil pump mark when you installed the timing belt? sometimes when you install the belt you can move the crank gear a little and not realize it and the motor will not be at tdc.
Check those.
When you instal a new head the VALVES need to be ADJUSTED!
Confirm the motor is at tdc, and do the valve lash to spec.
Remove the spark plugs and rotate the motor counter clock wise manually with a ratchet and cycle the motor at least 2-3 times and bring it back to tdc to confirm the timing belt is riding correct and the motor has not skipped a tooth on timing, then assemble the motor back and fire it up, if it sounds good check the timing with a gun correct the timing if needed and it should run fine.
Old Oct 15, 2012 | 04:55 PM
jreed773's Avatar
Yes sry shud have stated tht I did make sure all my marks and tdc were all set prior to putting the belt on I rotated the engine 6 times and everything is all good with the marks
Old Oct 15, 2012 | 05:38 PM
el crapitan's Avatar
check ignition timing. use a timing light
Old Oct 15, 2012 | 06:02 PM
jreed773's Avatar
Ok thanks guys for the help
Old Oct 15, 2012 | 06:05 PM
wunfstgsr's Avatar
Loved
Community Favorite
did you set the valve lash??
Old Oct 16, 2012 | 05:29 AM
JuicedUpRice's Avatar
right here is your problem.
do the valve lash.
.6 intake .8 exhaust
Old Oct 16, 2012 | 06:14 PM
jreed773's Avatar
Got it running the valves were not properly adjusted thanks guys for all the input
88 EF Hatch
Sep 18, 2009 03:54 PM
downest
May 23, 2006 10:05 PM
downest
May 23, 2006 08:36 PM
heygotboost
Aug 25, 2004 08:55 PM
Tad
16
Nov 14, 2003 01:05 PM
