Is this ok to remove??
Old Oct 16, 2012 | 07:26 AM
JuicedUpRice's Avatar
Default Is this ok to remove??
I have a question.probably a dumb one,but can you remove the big support brace/bar directly under the headers on a 91 integra?I dont know what it is called..
i see hatchbacks and have seen a few integras with it removed,just wondering if it takes something special to do it..
Its the big wide bar that has two skinnier bars that hook to the suspension on the wheel..
i can go take a picture if you dont know what im talking about.
Thanks in advance!
Old Oct 16, 2012 | 09:16 AM
doood's Avatar
been there done that
Default Re: Is this ok to remove??
that's a crossmember. why would you remove it?
Old Oct 16, 2012 | 09:43 AM
DeCePtEgRa's Avatar
You will lose stability but if you have after market front upper and lower braces I don't see it hurting. Pretty sure you have to remove it to run a lower brace but I could be wrong
Old Oct 16, 2012 | 09:59 AM
kyden's Avatar
you can remove it if you run a traction bar. you must understand that bar keeps the lower control arms from moving, as it only has 1 mounting point on the body.
Old Oct 16, 2012 | 11:12 AM
i was wondering because of fitment issues i was having with my turbo's downpipe..plus it just looks cleaner without it,and i like the spacious look.
but looks like i will just keep it there..
thanks for the info guys!
Old Oct 16, 2012 | 11:55 AM
DeCePtEgRa's Avatar
The support he is talking about doesn't even bolt to either lower control arms. Maybe you have to own one to know what your talking about. It goes from front to rear not left to right.
It bolts to the bottom of radiator support to the underbody of vehicle right in front of the cat.
Old Oct 16, 2012 | 12:15 PM
kyden's Avatar
he's talking about the front crossmember. the radius rods for the control arm bolt to them. also the front motor mount.
Old Oct 16, 2012 | 12:47 PM
DeCePtEgRa's Avatar
Ok op if possible can you put up a pic or diagram of this brace.I will try later on from my computer it will take to long to post it from my cell phone.
Old Oct 16, 2012 | 01:56 PM
3rdtimecharmer's Avatar
10 Year Member
Thanks in advance!
no such things as stupid questions, just stupid people. :x
jk.
Old Oct 16, 2012 | 02:07 PM
Old Oct 16, 2012 | 02:39 PM
DeCePtEgRa's Avatar
No that's the radiator support the one I thought you ment is the one bolted to center of the radiator support goin back to three bolt holes in the body. The one I thought may be needed for stability or oil pan protection.
It's where the front jacking point is for most Honda's
Old Oct 17, 2012 | 05:40 AM
kyden's Avatar
as i said, if you're looking for more clearance, get a traction bar to replace that.
Old Oct 17, 2012 | 06:01 AM
fcm's Avatar
fcm
Old Fart
What part...
Size:  20.0 KB ??? 94
Old Oct 17, 2012 | 06:22 AM
kyden's Avatar
he's talking about #3
Old Oct 17, 2012 | 07:10 AM
Creator's Avatar
Do not remove that without putting a traction bar in place. If you do your car will be a death trap.
Old Oct 17, 2012 | 07:35 AM
DeCePtEgRa's Avatar
Great diagram...here's your cookie kyden now go sit down its almost nap time..... So is brace #1 needed or can it be removed I scarpe the **** out of it lol
Old Oct 17, 2012 | 08:10 AM
Originally Posted by fcm
What part...
fcm,It would be part #3
i didnt even realize there is a goddamn motor mount on the thing lol..
i dont even have brace #1..
Old Oct 17, 2012 | 11:00 AM
fcm's Avatar
fcm
Old Fart
OIC, was hard to see on the vid.
Is there a "traction bar" that replaces that, I may be interested myself, I have a hard time hooking up when I am spraying.
Is there a link to the traction bar?" 94
Old Oct 17, 2012 | 11:17 AM
is this what we would need then?
http://www.ebay.com/itm/K-Tuned-Trac...c2bb86&vxp=mtr
Old Oct 17, 2012 | 04:32 PM
fcm's Avatar
fcm
Old Fart
Maybe for you, I have a 94.
I am not seeing how that would replace the cross member or even where the front stopper would mount to? 94
Old Oct 18, 2012 | 06:09 AM
kyden's Avatar
he has a 91 integra.
Old Oct 18, 2012 | 06:10 AM
kyden's Avatar
a traction bar doesn't increase traction as the name would say. it helps the control arm from rocking causing wheel hop.
Old Oct 18, 2012 | 11:10 AM
fcm's Avatar
fcm
Old Fart
I know, that's the problem I have.
When I autocross and I come out of a corner, I get on the throttle, a little, untill it hit my "turnout" point then I go to WOT and start spraying, sometimes that will produce wheel hop, [Yokahama O32Rs] resulting in loss of traction.
If I can prevent that I can shave .5 sec. or more off my times, and in Solo 2 that would be huge. 94
Old Oct 23, 2012 | 04:46 AM
Creator's Avatar
Juiced:That looks like the one you need. Not sure how much they usually go for, but I imagine you could find a cheaper solution. I'm just starting to get into the DC's been an EF guy for years now.
I believe that you lose quite a bit of traction under wheel hop, so kyden, your statement is counter active.
fcm: I haven't had the chance to go to any autocross events yet(I time trial), but my EF doesn't wheel hop out of tight corners. It has an Innovative mount front traction bar. I used to have a CRX that did exactly what your talking about, as far as accelerating out of a corner. It had the stock front crossmember.
0NE600
Mar 7, 2011 10:21 AM
happycorey
Suspension & Brakes
19
Jun 19, 2009 03:16 PM
racer_X_123
Welding / Fabrication
59
Sep 21, 2005 08:22 AM
handa
Jul 28, 2003 10:02 AM
