b18b piston ring size???
Old Oct 4, 2012 | 05:56 PM
Jitterbug831's Avatar
Default b18b piston ring size???
ok so am replaceing the piston rings on my b18b and on the top of the piston it has .8 on every piston, i done some research and found that it means that my pistons are 81.08 but cant find any info on what rings to use with this poston so do i just use the stander size or over size .25 or .50 any info will help thanks
Old Oct 4, 2012 | 06:18 PM
01oemTeggy's Avatar
Default Re: b18b piston ring size???
Get the std (standard size) for 81mm, you will be fine.
Old Oct 4, 2012 | 06:20 PM
Muckman's Avatar
Moderator in Chief
81.08 is not a size. If you haven't replaced the pistons then they are standard size 81mm and call for 81mm rings.
Old Oct 4, 2012 | 06:38 PM
So what dose .8 on the top of the pistons mean???
Old Oct 4, 2012 | 07:27 PM
Muckman's Avatar
Moderator in Chief
No idea. Are the pistons stock? Do you have a picture?
Old Oct 4, 2012 | 07:52 PM
Old Oct 4, 2012 | 11:16 PM
01oemTeggy's Avatar
If you havent bored out the block you will need standard size. Ignore those numbers.
Old Oct 5, 2012 | 02:07 PM
kchungb17a's Avatar
That is usually just to designate that that piston was for a USDM engine, etc. As everyone else has stated: if your engine has never been apart then use the standard size rings. Should rehone the cylinder too.
Old Oct 5, 2012 | 04:08 PM
Ok thanks for the info
What rings do you guy recommend? Is ther any good aftermarket ones? This is my daily driver about 40 miles a day I drive it normal no racing or bashing on it thanks for any input
Old Oct 5, 2012 | 04:59 PM
kchungb17a's Avatar
OEM all the way. Make sure you or whoever is building your engine measures cylinder specs to make sure you are within service limits. And always check ring end gap.
Old Oct 5, 2012 | 05:34 PM
1998GsRIntegra's Avatar
And also make sure who ever builds it doesn't put like a 240grit hone job on it. That is way too rough for the thin honda piston rings. I think factory service manual calls for something like 400grit but don't quote me on that. I sent a block off to get honed one time and it came back with about a 200grit job. Had to send it back to be redone. Somewhat my fault for not mentioning what grit to hone it at, but the machine shop was cool and took care of it free of charge.
Old Oct 5, 2012 | 05:50 PM
kchungb17a's Avatar
Yes the OEM service manual calls for 400 on the final hone.
Old Oct 5, 2012 | 06:43 PM
01oemTeggy's Avatar
I have nipping piston rings on my built b18c and they rev to 9 rpm every day with no problems. But if u have cash then I would go with OEM.
diatibe24
Engine Machining & Assembly
Mar 25, 2024 02:33 PM
Quetzolcotl
Mar 20, 2003 08:50 AM
GreenR
Jan 29, 2003 03:39 AM
