Heater Core
Old Oct 15, 2012 | 03:29 AM
mr.mengo's Avatar
Default Heater Core
Hey guys, i have a 94 GSR and the heater core is leaking. Any Suggestions on how to fix the problem. Ofcourse, might have to move the whole dash. Any tips will do. Thnxz.
Old Oct 15, 2012 | 11:03 AM
kchungb17a's Avatar
Default Re: Heater Core
If the core is leaking, there's no getting around removing the dash.
Old Oct 15, 2012 | 03:22 PM
wunfstgsr's Avatar
Loved
Community Favorite
wheres it leaking from! in the engine bay?
Old Oct 15, 2012 | 05:15 PM
lawjdl16's Avatar
just loop the hoses..unless you need heat..then you have to pull the dash
Old Oct 18, 2012 | 07:21 PM
mr.mengo's Avatar
its leaking from the passenger side inside the car...i checked the engine bay already, no leaks from there.
Old Oct 18, 2012 | 07:22 PM
mr.mengo's Avatar
i bought the car like that and i dont really see ani hose underneath the dash so ughhh.....maybe i mite need a new hose...
Old Oct 18, 2012 | 10:43 PM
Dynasty21's Avatar
From: Where We Squeeze 1st N Ask Questions Last, CA, USA
I think he meant looping the hose that feeds coolant to inside the car and the return line. No coolant cycling in the core means nothing to leak inside the car.
Old Oct 19, 2012 | 11:13 AM
racebum's Avatar
you have to pull the dash, the heat vents and drop the steering column. it's a similar amount of work to pulling an engine. maybe slightly more. i did one on my old integra. the core is like 30 bucks on rock auto but the install takes awhile. it's not really a hard job, just time consuming.
till you fix it locate the two ports on the engine bay firewall that feed it and connect the two lines so you bypass the core.
you won't have heat but it will stop the coolant leak in your interior
i'm not surprised that someone would sell the car rather than fix this.
i would imagine that shops would want around 800-1000 to fix this
Old Oct 19, 2012 | 11:27 AM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^ a dash pull is needed and a heater box removal, a heater box "split", to replace the heater core.
As mentioned, not that hard, just time consuming, if you know what you are doing the dash can be pulled in about 1hr, [all the way out of the car] with hand tools, [no air/power tools] it is more like 2.5hr.
Also as mentioned, loop the heater hoses to take the heater core out of the loop, so your not leaking coolant into the car.
This is also a good time to do anything else behind the dash, replacing damaged dash harness, a stealth alarm install, definatly make a list of anything that is wrong and may be repaired while dash is off. 94
Revolver123
Honda Civic (2001 - 2005)
Nov 12, 2008 04:07 AM
mengy007
Sep 14, 2007 09:34 AM
mrsalesco
May 23, 2007 10:01 PM
1PT-SICK
Apr 18, 2006 07:39 PM
LSEGHATCH
Dec 11, 2005 11:02 AM
