Ac not as cold.......
Old Sep 26, 2012 | 02:23 AM
si_motor_spt's Avatar
Default Ac not as cold.......
Hey guys, one more quick question, when i turn the ac on, i can hear and feel the clutch engaging on the compressor but it jus dosent seem cold at all, i mean i live in az but everyone elses cars seem cooler.......would it jus be low on refrigerant or too much?
Old Sep 26, 2012 | 04:58 AM
fcm's Avatar
fcm
Old Fart
Default Re: Ac not as cold.......
Most likely low, but an overcharge would result in high head pressure and higher vent temps, only way to know for sure is to connect up a set of gauges. 94
Old Sep 28, 2012 | 12:12 PM
okay so i jus realized that the condenser fan dosent come on when the ac is on so im sure thats its not as cold as it should be, anyway to test it?fan?relays?
Old Sep 28, 2012 | 04:53 PM
fcm's Avatar
fcm
Old Fart
If condensor fan does not turn on head pressure will increase and go well above 200-250 PSI and the result is the same as an over-charge, poor cooling.
MM&Y of car?
Unplug the condensor fan and supply power and ground directly to it to see if fan is good. 94
Old Sep 29, 2012 | 02:55 AM
its a 01 gs integra/ b18b1
Old Sep 29, 2012 | 03:09 PM
dc2LS's Avatar
I had the same problem a while back I just wired up my condenser fan direct so when ever the car turns on it automatically turns on.
Old Sep 29, 2012 | 09:00 PM
fcm's Avatar
fcm
Old Fart
The condensor fan relay is in the engine bay fuse box, unplug the relay and test for power, with the ign. switch off, there should be one pin that is 12V+, [hot at all times].
Turn on the ign. and you should find a second pin with 12V+, [switched power] if you have both powers, fusing is not the problem.
The 4 pin relay is numbered, the 12V+, [hot at all times] will be #30 or #87, either way, [as long as one has power] use a paper clip to jump the two pins, [#30 and #87] ign. does not have to be on, if fan turns on the circuit and fan are good.
To test the relay, swap it with one of the others, if condensor fan works, the relay is the problem, if not it will be relay control.
To confirm it is relay control, supply the relay coil with a ground.
The second 12V+ pin, [switched] will be #85 or #86, plug the relay part way back in, use a jumper to supply a ground to the pin THAT IS NOT the switched switched 12V+, if fan turns on the relay is good and relay control is the problem.
The condensor fan relay is controlled by the A/C switch on HVAC control, through the A/C thermostat and the A/C pressure switch and finaly through the A/C diode, it should turn on as soon as you turn on A/C, meaning it can only be the A/C diode that is bad because the compressor turns on, the A/C diode is there so when A/C turns on the condensor fan, the rad fan also turns on, but condensor fan does not turn on if just the rad fan turns on for engine temp. 94
geribair
Jun 7, 2014 11:18 AM
duyfash0
Oct 8, 2008 06:46 PM
itsalmostfrieday
Mar 31, 2007 06:58 PM
oMek
Jul 6, 2006 04:38 AM
jazz215
17
Jul 27, 2003 05:17 PM
