Suspension Problems
Old Sep 29, 2012 | 11:49 AM
averageguy635's Avatar
Default Suspension Problems
My 94 integra is way to low, how do I raise it up...and if stock is the only way, where can I find some stock
Old Sep 29, 2012 | 01:14 PM
macDelli's Avatar
Default Re: Suspension Problems
are you running a flat drop spring or a coilover set-up?
Old Sep 29, 2012 | 01:15 PM
b20bFourDoorCivicLX's Avatar
are they adjustable? if not your better of just going with some ground controls so you can adjust your height, plus while your there replace your struts....why would u go stock? if you want stock go to Auto-zone.
Old Sep 29, 2012 | 02:08 PM
well, I tried autozone, they dont have stock....its just too low for where i am....the roads suck and im not trying to buy new oil pans.....its only about 3 inches off the ground....im new to the acura thing needed something good on gas.....
Old Sep 29, 2012 | 02:10 PM
Im not sure....I believe its coilovers,but im not sure, like i said im new to this and jus needed something good on gas
Old Sep 29, 2012 | 02:24 PM
well have someone jack up your car, take off your tires and take a look, you said your not sure what you have? maybe if your lucky their adjustable, but to me it sounds like you have some no name brand after market springs so you're probably going to have to upgrade or good luck go to a acura dealer ship and buy oem stock parts....goodluck, share some pictures!!
Old Sep 29, 2012 | 02:54 PM
how would i know if it is adjustable...i do all the work on my own cars, but im used to big bodies and things like that....but I like the integra....
Old Sep 29, 2012 | 04:21 PM
also if I upgrade to the adjustable coilovers how much will it raise my ride height....cause as of now there is no gap between the wheel well and tire and makes for a really rough ride....hate to hear the tire and wheel bounce off the wheel well
Old Oct 2, 2012 | 08:21 PM
well I found out what they did to lower it, they cut about 2 1/2 inches off the stock springs.........will share pics when I can add attachments
Old Oct 2, 2012 | 10:49 PM
dickdragon's Avatar
SMH! Autozone doesn't have stock.
Old Oct 3, 2012 | 07:34 AM
Creator's Avatar
That's the worst way to lower a car. I'm sure it does ride like crap. At this point your shocks are probably trashed too (no telling how long it's been like that). It would depend on how much clearance you need. Do some searching, don't have time to do it for ya. Try searching spring rates (usually theres a break down with ride height). You'll probably need new bump stops too(check dealership).
Old Oct 3, 2012 | 10:54 AM
Ryan96GSR's Avatar
I've seen some aftermarket OE spec springs out there. Usually sell for around 120 a pair retail.
I went with the H&R OE springs. They're a about a 1" drop from stock once they settle.. Same height as the ITR.
Old Oct 9, 2012 | 08:24 AM
got a new problem, when i put the car in reverse,it backs up fine until i have to stop there is like a jerk.....or if im backing up and need to stop and then try to back up again i push the gas and it doesnt go anywhere.....unless i put it in gear and then back up again then there is the jerk when i stop
TOO MUCH TORQUE
Suspension & Brakes
24
Mar 7, 2012 04:59 PM
BMRALR
Suspension & Brakes
Nov 22, 2007 08:10 PM
type B16
Nov 23, 2006 11:48 AM
xunkn0vvnx
Mar 25, 2006 06:34 PM
hondatowork
Jul 7, 2004 02:50 PM
