alarm starter kill problem
Old Oct 5, 2012 | 08:20 AM
vtecdc4's Avatar
Default alarm starter kill problem
1995 integra se
went to change the battery of the car and the car just wont start anymore.
the cars getting power, the alarm did this before but i got it to work some how. im pretty sure the alarm engaged the ignition kill and it wont disengage. the problem is the alarm wont work anymore, the remote doesnt work and i tried everything. disconnected fuses, disconnected and reconnected the brain and nothing happened. when i push start the car it works. its an older clifford alarm. the alarm is getting power but it just wont work....
help.....
Old Oct 5, 2012 | 01:59 PM
kchungb17a's Avatar
Default Re: alarm starter kill problem
There should be a momentary switch somewhere under the dash. Try holding that down while you switch the key into on position. Do not release the switch for as long as 10 seconds. If that doesn't work, just go under the dash and reconnect the starter wire. It's the big black wire with white stripe coming from your ignition switch to the fuse box. Use a crimp butt connector or solder or both.
Old Oct 5, 2012 | 02:51 PM
vtecdc4's Avatar
k going to take the bottom of the dash apart right now. will come back if i have more questions(probably will)
Old Oct 5, 2012 | 05:06 PM
vtecdc4's Avatar
so i checked it out, i see what black and white wire you are talking about. took a multi meter to the ignition and all the wires read 12v except the black and white one, BUT when i use the multimeter on the plug to where the ignition wire is coming from im not getting 12v...is this normal??? dont wanna have to cut any wires unless i have to
vtecdc4's Avatar
starter reads 12v aswell, all fuses are good....alarm still wont work...
Old Oct 5, 2012 | 05:23 PM
kchungb17a's Avatar
Just to be clear: your car does not crank, correct? When you turn the key nothing happens.
The black/white wire is the starter signal wire. It will only see 12v when in cranking position with the key, and only on the wire coming from the ignition switch. With the key in crank or start position, you should see 12v coming from the switch.
This is the wire that is cut and spliced into your alarm, yes? If so, cut it out of the alarm harness and reconnect it. Try to cut as little as the black/white wire off as you can so that it isn't too short. You may need to extend it due to the cutting and splicing.
Hope that helps.
Old Oct 5, 2012 | 05:41 PM
vtecdc4's Avatar
Hope that helps.
edit; just understood what you were saying. ill give it shot. fingers crossed
Old Oct 5, 2012 | 06:07 PM
vtecdc4's Avatar
it worked, thanks for your help bro!!!
Old Oct 5, 2012 | 06:14 PM
kchungb17a's Avatar
Sweet.
You should be able to pull the alarm module out and be good to go.
peter_vang
Mar 26, 2010 08:31 PM
Civic-Kids
Audio / Security / Video
Aug 12, 2009 03:03 PM
8krdline
Sep 15, 2005 05:21 AM
I Gotta Question
Jan 26, 2004 07:33 AM
Se-rv-Tak
Jan 22, 2004 09:18 AM
