Need to Replace Clutch -- Advice?
Old Mar 8, 2013 | 03:36 PM
tomstarritt's Avatar
Icon2 Need to Replace Clutch -- Advice?
Oem clutch is old, and doesn't grab. Time for a new one. Engine is currently stock (B18). Not planning on going much over 200hp, but figure i might as well upgrade the clutch a bit. Leaning toward stage 1 exedy, and a lighter flywheel. Looked at XTD and F1 and heard too many horror stories. All advice welcome.
Old Mar 8, 2013 | 04:32 PM
fcm's Avatar
fcm
Old Fart
Default Re: Need to Replace Clutch -- Advice?
I run an ACT clutch with the stock flywheel, 94 RS W/GS-R transmission and a 75 shot ZEX kit, no problems on the autocross coarse or DD. 94
Old Mar 8, 2013 | 05:23 PM
Thanks. Just curious what stage clutch you're running, as well as power #'s on the motor.
Old Mar 8, 2013 | 05:47 PM
B20ztek's Avatar
F1 is the same as SPEC clutches btw.
Ive ran the stage 2 and stage 3 in two different cars, loved it. Super grippy
Old Mar 8, 2013 | 06:14 PM
racebum's Avatar
with the internet deals on the exedy1 it would be my choice. holds up to autocross and has stock like engagement.
clutches are one place where more is not always better
Old Mar 9, 2013 | 04:17 AM
S2BumpsticksGSR's Avatar
Don't go too light on flywheel if you drive on big hills/mountains. The lighter you go the less momentum will be stored in flywheel. If you're in the flats, no prob.
Old Mar 9, 2013 | 10:28 AM
3rdtimecharmer's Avatar
10 Year Member
theres a whole section on clutches and flywheels. pretty good read. look it up using search.
Old Mar 10, 2013 | 08:14 AM
fcm's Avatar
fcm
Old Fart
With the 75 shot I am at a hair over 200HP, using the AI4-HDSS. 94
xkrntamax
Mar 27, 2010 04:55 PM
down_the_hatch
Aug 19, 2009 02:04 PM
xintegr
Mar 26, 2006 06:25 PM
allstockb18c
Jul 3, 2005 12:44 PM
DsITR
Jan 4, 2003 11:25 AM
