1995 Acura Integra SE progress thread.
Shit Posts: 15
Hello all. My name is Serafin. I'm 19 & I've been into car for about 3 years now.
I've been on the site for a year or so but not very active. I'm getting active now.
here's my car.
quick story. got the car February of 2011. crashed it march of 2011. had it fixed may of 2011. repainted July of 2011. did lsv swap October of 2012.
want to start a 500 hp build soon. was going awd, crv trans isn't strong enough. saying fwd for now. unless I feel like too much power is lost to wheel spin. them rwd conversion will come. here's some pics. thanks for looking.
first day.
17s
wreck
stripped
fixed.
new rims
painted
dropped
assembled
intake
exhaust
painted rims gold and got tires. 1 yr later
evil eye lids
diff intake. (current)
lsv time
control arms. Godspeed
here's how it sits now. (new foglights)
some engine specs and car specs.
167k miles on block.
got a GSR head for basically for 75$
so. GSR head. v tec pumps and GSR belt.
chipped p75 ecu.
rev limit 7800 rpm
cel shift light 7700 rpm
v tec 5000 rpm
iab open 4500 rpm
2 step launch 5000 rpm
thanks. enjoy.
here's my car.
first day.
17s
wreck
stripped
fixed.
new rims
painted
dropped
assembled
intake
exhaust
evil eye lids
lsv time
chipped p75 ecu.
rev limit 7800 rpm
v tec 5000 rpm
iab open 4500 rpm
thanks. enjoy.
Shit Posts: 15
Re: 1995 Acura Integra SE progress thread.
thank you sir.
well I had 1 idea for the rwd. awd crv trans with no front axles. but since it's not strong enough that idea is in the trash.
a friend of mine is building a 4g63 and he is mounting the engine 90 degrees in rotation. like a 240 engine.
so if he can do it. why can't I?
yea why do this in the Acura when I can buy a 240? 240s are known for rwd. not many rwd Acuras out there.
yea it'll require heavy modification.
some firewall delete, front subframe modification. those are my biggest problems. I see the read diff and drive shaft and rear axles as cake compared to this...
All this if course if I feel like high hp numbers aren't getting the launch they deserve...
The 500 hp is a for sure. rwd is iffy.
just waiting on one of my jobs to really take off so I can start my build.
engine will be built by me. fab work will be done by me if it does occur.
so no money being spent on someone else's labor. just on parts.
car looks nice. 100x better after paint and the gold rims look really good with that blue.
a word of warning though. If you didn't do any work to that bottom end, 7800 rpm will kill it fast. LS rods have weak bolts in them, and don't take kindly to revs higher than the stock limit. I wouldn't go very much past about 7300-7400 on stock rods (and that's only based off the fuel cut being set to 7200rpm
Shit Posts: 15
Shit Posts: 15
Shit Posts: 15
but thanks for that info. I'll keep it under 7500 now.
when I got the head. I just resurfaced it and put it on.
I didn't think of valve guides. and now it burns oil sometimes I blame the guides. because before it wouldn't burn any oil so i don't think it's the rings.
I hardly drive it right now. mostly drive it when I don't want to spend a fortune on gas in the Infiniti. and I knew very little about cars when I got the Acura so I put a fart can on it(ANNOYING). probably the only downside. no now that I have a welder. I'm putting the stock back on in the next week or so.
but thank you.
Shit Posts: 15
I've realized my piston rings are going out little by little. oil is being burned now.
change of plans too. no mas 500 hp.
have plans for something else.
as of now. I'm just gonna get a b18a Jdm block sleeved to 84mm and use main/head/rod arp bolts. forged rods and pistons.
going to use oem crank and oem gsr head and a turbo. trying to peak 370-400
Shit Posts: 15
Boy what plans huh?!?^^^
Lol
500 hp. Iffy rwd. Damn!!
None of that ever happened!!
After trying to salvage my engine,
I rehoned the block myself. Threw hasting rings in.
Ran good, then a loud knock/ticking noise came about.
Thought it was a bearing. Pulled the engine out, drained the oil, didn't see any shavings.
Don't know what the issue with it was.
But I got another engine for it. B18a1.
Here's pics&progess.
Cut my am inch or so out of my shifter and welded it back up
Got horrible exhaust leak fixed
Old engine pulled
Had bad oil leak
DISGUSTING
New to me engine
Time to get cleaning
Adjusting valves for compression
It's pretty clean. But not clean enough.
Gonna paint it aluminum tomorrow hopefully
Cleaned the nasty engine bay and got it one color!
Wheel wells and subframe being painted black tomorrow
Black headlight covers
Black abs motor
New rack boots
Re did wiring harness
Injen cai
Harness and intake and shift boot chillin in the room
How it sits right now
Tow hooks now black
I did get oem shocks and going to use skunk 2 springs
What's to come
Here's some just cuz pics. Back in the day
Sex
What's to come, actual ice box with ice maybe done tomorrow, and...idk what else haha. I'll post pics and info.
Lol
Old engine pulled
Had bad oil leak
DISGUSTING
New to me engine
Black abs motor
New rack boots
Injen cai
Tow hooks now black
What's to come
Sex
Shit Posts: 15
Shit Posts: 15
Oh what's to come.....
Power steering reservoir relocation. Under fender. Above fender guard
Hid ballast and headlight wire tuck
Extended top hats and ice box. Not till car is running tho
Maybe too hats this week.
Also re barrled steelies soon.. Either all chrome or black and chrome Lip
Cabin filter too, DIY to come for that
Gauge pod assembly soon to be all installed as well. Oil press. Water temp and voltage.
Picked up oem flare. Have to put that one
Anyone know the location in the cabin where these go?
Shit Posts: 15
Little progress
Adjustable cam gears!
Reservoirs back on and little clutch reservoir tuck. Nothing big
And Some other stuff
I'll leave this up to your imagination.
Coolant T fitting for thermostat gauge
Brake booster line and reservoir tuck
Power steering pump on
Gears on. The smart man will see what is going on.
Got too lazy to put back in the garage. Covered up
http://i173.photobucket.com/albums/w...psdf3edy2f.jpg
Shit Posts: 15
Shit Posts: 15
Got some stuff done and some new stuff.
B20 VC. Polished it. Polishing isn't finished yet.
Before
http://i173.photobucket.com/albums/w...ps3af60d84.jpg
After
New pcv valve and rubbers to covers some I'm ports
Door visors
Megan racing bar!! :drool:
Installed
Installing rear lower tie bar soon and from frame support bar
Will be bolted between radiator and exhaust manifold
Did some manifold work
Before
After
Will that help^
I'm sure it will.
Will I notice it?
Idk.
But in the back of my head I'll have peace of mind
Still wanna blend the tb to the manifold. Pics to come.
And a little teaser.
Before
After
Door visors
Installed
Before
After
Will that help^
I'm sure it will.
Will I notice it?
Idk.
Shit Posts: 15
Wow so much in 1 page! Haha
Some updates
This weather and lack of a clean garage is making this build so slow!!!
Polished parts
Have b20 VC polished but no pics
Engine mounts and heat shield and pulley
Cleaned up the flywheel and pressure plate
Although it is really smooth
I'm thinking of taking a wire wheel to it to rough it up?!
Gotta have good sound
Finally put the IM on for good!
Ports and polished, ports covered up.
Just have to put and oil pressure sensor T on to drop the engine.
Don't wanna drop it and and have to deal with the T on the block while it's in, such a pain in the ***.
Also got magna flow exhaust
Some updates
Polished parts
Shit Posts: 15
Ports covered and oil pressure gauge T
http://i173.photobucket.com/albums/w...psjkm0iorw.jpg
Manifold painted black.
http://i173.photobucket.com/albums/w...ps93w4vbbt.jpg
T belt on and acc pulley )))
