problem with suspension
Old Mar 5, 2013 | 07:56 PM
manuel351's Avatar
Default problem with suspension
hi everyone im new to the forum i got a 93 ls da lowered on coilovers the problem is that the car is wide open on the front way wide open is there something that i can do or put on it to fix it or should i higher the coilover to a way that the schocks dont get too wide? sry if i couldnt explain it better my english aint the best. and another question wich header is the best for around the 180 bucks cause my money is kinda low right now thank
Old Mar 5, 2013 | 08:09 PM
B_Swapped93's Avatar
Default Re: problem with suspension
By open what what do you mean....Camber you wheels are "pointing out" like this:
you won't find a good header for 180.00. Decent/ok header will be 400.00+
Old Mar 5, 2013 | 08:31 PM
manuel351's Avatar
exactly like that and honestly dont like it
Old Mar 5, 2013 | 08:37 PM
you can start by raising it that will help i don't know if that will fully fix the "negative camber". save that 180.00 for fixing this that's you'r best bet IMHO.
Old Mar 5, 2013 | 08:50 PM
el crapitan's Avatar
buy a camber adjustment kit
Old Mar 5, 2013 | 08:57 PM
forgot what they were called but that's you'r best bet.
Old Mar 5, 2013 | 09:03 PM
doood's Avatar
been there done that
this is what happens when you dont know what you're doing, and you do it anyway.
Old Mar 6, 2013 | 11:26 AM
UndergroundTrev's Avatar
10 Year Member
Raising it up a little will help. A camber kit should fix it completely. You can get camber kits that replace the whole upper control arm and have adjustable ball joints, or there are less expensive ones that attach to the ends of the control arms where they bolt to the strut towers.
Jdmintegr
Apr 9, 2012 08:39 PM
HFP-EP3
Mar 22, 2010 07:09 PM
latrungkiet
Jul 5, 2005 03:33 PM
George H
Jul 12, 2001 12:00 PM
George H
Jul 11, 2001 07:07 PM
