Running Light Issue 2000 LS
Old Mar 5, 2013 | 07:45 AM
TYLER3's Avatar
Default Running Light Issue 2000 LS
Like the title says I have a 2000 Integra ls. Before I put my car into storage for the winter my cigarette lighter stopped working and a day later my dash lights along with my running lights went out. My brake lights, blinkers, reverse, hazard, and headlights work just not my running lights. All of the fuses were fine so I replaced the headlight switch and the dimmer switch with known working ones and this did nothing. It is not a fuse I've checked both fuse boxes multiple times and even replaced good fuses. Could it be as simple as a bulb needing replaced? Would the cigarette lighter have an effect? Has anybody had this happen to them? Any input would help, i'm not the best at wiring. Thanks
Old Mar 5, 2013 | 11:02 AM
fcm's Avatar
fcm
Old Fart
Default Re: Running Light Issue 2000 LS
It will not be a bulb, if it was they would all have to be burnt out.
You said you checked the fuses, how did you check them?
Have you checked to see if there is power at the tail/dash light fuse when park/head light switch is on?
have you tested for power on the red/black lead at the DLBC, [dimmer switch] when park/head light switch is on?94
Old Mar 7, 2013 | 06:41 AM
TYLER3's Avatar
Thanks for the input I will do this during the weekend and post my results.
Osmosis
Aug 31, 2015 02:45 PM
EGdope
Jun 26, 2012 09:21 AM
JDM EK_97
Apr 19, 2012 07:36 PM
skullbiz
Feb 12, 2010 11:26 AM
mister_r0b
Jul 16, 2004 10:42 AM
