Starter problems
Old Mar 7, 2013 | 10:46 AM
MMMGIRL's Avatar
Default Starter problems
I just finished putting a B18A1 in a 90 DB1, everything works fuel pump primes and all but the car wont turn over. When the starter is on the car hooked up it just clicks or somewhat pops once, when I jump it from the battery the solenoid just clicks however when I take it off and jump it it works fine. Im sorta lost on what to do all input would be appreciated.
Old Mar 7, 2013 | 12:26 PM
MMMGIRL's Avatar
Default Re: Starter problems
Bypassed the clutch switch and changed the fuse under the dashboard and its still not working. The starter may be engaging just not spinning. Whenever I jump it from the battery it engages but wont spin.
Old Mar 7, 2013 | 12:46 PM
MMMGIRL's Avatar
You can close this thread I fixed it. I removed all the ground and they were pretty corroded, cleaned them off and turns over like a charm.
namblagambla
Aug 13, 2013 09:50 AM
timaccord95
Sep 5, 2011 05:28 AM
Jonathan_ED3
Aug 14, 2008 06:15 PM
go2sleep
May 6, 2007 08:42 PM
Superhatch
Dec 14, 2002 02:58 PM
