91 ls map sensor issues! please help!
Old Mar 6, 2013 | 05:57 PM
srqslop's Avatar
Icon3 91 ls map sensor issues! please help!
Hey guys, thanks for any and all help! I have this 91 inetgra ls thats going thro map sensors like crazy. I have put 2 from the local u pull and now 2 brand new oem ones. Is there anything that could cause my car to do this? Oh, it will shut off with no sign of anything. Just driving then off. It threw a map sensor could so i assumed that was the problem. Im starring to think its more but thats tge only code i get.
Any otger ideas?
Old Mar 6, 2013 | 06:56 PM
B_Swapped93's Avatar
Default Re: 91 ls map sensor issues! please help!
Do you have another ecu you could try ? i would have quit after 2 let alone buying new oem ones.
Old Mar 6, 2013 | 07:50 PM
el crapitan's Avatar
maybe you're reading the code wrong.
what is the exact code you are reading?
a bad map sensor/circuit shouldn't cause a stall
Old Mar 7, 2013 | 09:26 AM
srqslop's Avatar
I kinda started thinking that..... did a little more research and figured out i read the code wrong. Its code 15. So i was gonna replace the whole distributor. But undecided as to go with an msd with external coil or an oem. I can get either for about $100. The msd doesnt have a wiring diagram tho. Any ideas here?
Old Mar 7, 2013 | 07:17 PM
that sounds more like it. you can replace just the icm though. if you go the route of replacing the whole sha bang, i would just go oe replacement.
Old Mar 11, 2013 | 09:50 AM
srqslop's Avatar
After doin a littke more looking i found a hondata chipped and plugged ecu for $170. I figure i can get the distributer and ecu for $300.
Old Mar 11, 2013 | 10:34 AM
srqslop's Avatar
Ok......car just died at lunch......ive had enough. Napa had an icm in stock! $43 it is going in after work! Ill let yall know how it goes. Thanks for the advise thus far gentlemen.
Old Mar 11, 2013 | 04:22 PM
srqslop's Avatar
Ok.....so far so good. Car is running good. Thanks guys!!
Kuppa
Sep 26, 2009 04:11 PM
FSS13foxtrot
Jan 20, 2008 06:23 AM
TRYLSTEG808
Jun 14, 2007 10:51 PM
chrysler kid
Sep 28, 2004 07:24 PM
barry11j
Aug 4, 2004 09:45 AM
