how do you clean
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIC_jdm_da9 »</TD></TR><TR><TD CLASS="quote">here and it works.... http://www.team-integra.net/se...D=662</TD></TR></TABLE>
its dirty on the inside....read first
to the op take off your head light housing of the car and use a power ball mini through the holes for the lights. it'll fit and work great cause the head light is round
good luck
good luck
take off all the silicone around the lense with and exanto knife and a flat heat screw driver (be careful not to chip or scratch the lense, then wet sand with 1500 grid and buff it from the inside and if u have to put a clear coat on both sides and then reseal it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinoy2o9 »</TD></TR><TR><TD CLASS="quote">will that neverdull worh on the one piece headlight off the 90-93 integra? looks good on the HOW-TO on team-integra</TD></TR></TABLE>
for the one pieces u have to wet sand with atleast 1000grit or finer
then use neverdull or i like to use a plastic cleaner and then a special plastic polish i got from a local detail shop
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project95LS-VTECNoMore »</TD></TR><TR><TD CLASS="quote">Bake and clean</TD></TR></TABLE>
RoaringTurtle
Jan 18, 2005 07:43 PM
