NEED HELP,FAULT CODE 20(ELECTRICAL LOAD DETECTOR)
Old Sep 23, 2007 | 04:46 AM
skunkiemonkeynutz's Avatar
Default NEED HELP,FAULT CODE 20(ELECTRICAL LOAD DETECTOR)
hey i have a jdm 91 da6 running a b18cr with obd0 loom, obd1 ecu with 0bd0-obd1
boomslang ecu conversion harness.
the problem is wen the obd1 ecu is pluged in it doesnt want to start,its as if its
not getting enuf fuel n throws code 20(electrical load detector).but then when i plug the old obd0 ecu back in it starts up fine...
can anyone please point me in right direction on were to start!
ive gone thew all the wiring n everything n now running out of ideas
cheers
Old Feb 25, 2008 | 05:33 PM
hatchback freek's Avatar
Default Re: NEED HELP,FAULT CODE 20(ELECTRICAL LOAD DETECTOR) (skunkiemonkeynutz)
it might be the fuse box, you need to replace it
Old Mar 4, 2008 | 03:51 AM
Default Re: NEED HELP,FAULT CODE 20(ELECTRICAL LOAD DETECTOR) (hatchback freek)
check fuse #15 under the dash
waspcrx19
15
Apr 9, 2011 02:28 PM
hfraziers
Feb 10, 2010 05:47 AM
CRXDaddy78155
Sep 4, 2006 05:46 AM
ViXoN Hatch94
Jun 21, 2006 12:43 PM
