Grinding!!!
Old Sep 24, 2007 | 11:30 PM
Nicks95GSR's Avatar
Default Grinding!!!
Everytime im going to shift to second gear it seems to grind, however it only does it in high RPM's... Any suggestions??? Help??? Is it time for a new clutch???
Thanks HT Members
Old Sep 24, 2007 | 11:42 PM
1200 Hobos's Avatar
Default Re: Grinding!!! (Nicks95GSR)
Kunem Beranat SUKA. Search GM synchro mesh before it gets worst and put the "friction modified" version in your transmission as your oil. Give it a week or two to work it's way in. Should solve the problem if it is infact your synchros that are acting up. Goodluck.
Old Sep 25, 2007 | 12:02 AM
clean3two3's Avatar
Default Re: Grinding!!! (1200 Hobos)
yea my third scratches but they told me it may be that it is not aligned right but they also told me to add transmission fluid
Old Sep 25, 2007 | 12:11 AM
LordAphotic's Avatar
The transmission has these parts inbetween the gears called synchronizers...
after years of not changing the oil or grinding gears a lot or abusive driving... the synchros wear out....
but theres a set of synchros for every gear....
so its totally possible to just wear out the synchros for 2nd or third gear... those are actually the most common ones that wear out cause those are the ones people slam it into gear when driving fast...... and if u miss a shift and you hear that grind... thats the synchronizers grinding for whatever gear your trying to hit....
If its a grind in the super high rpms only then there is wear but not a lot of wear yet... but little by little grind by grind .... shift by shift.... your eventually not gona be able to shift into that gear....
Either learn how to open your tranny and change all the synchronizers so it shifts like a new ttranny again.... or buy a used or new tranny in better shape.
Old Sep 25, 2007 | 02:57 AM
Doostur's Avatar
^ I agree. I have had the same problems. Synchros FTL
Old Sep 25, 2007 | 06:09 AM
Mfoehrkolb's Avatar
go go syncros
Old Sep 25, 2007 | 06:43 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: (Mfoehrkolb)
syncromesh
Old Sep 25, 2007 | 09:05 AM
Nicks95GSR's Avatar
Default Re: (St Jimmy)
And where can I get that Synchros fixed??? How much $$$$, how long does it take to get it done???
Thanks HT Members!!!
Old Sep 25, 2007 | 09:23 AM
Nicks95GSR's Avatar
Default Re: (Nicks95GSR)
Old Sep 25, 2007 | 09:28 AM
St Jimmy's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1200 Hobos &raquo;</TD></TR><TR><TD CLASS="quote">Search GM synchro mesh </TD></TR></TABLE>
http://www.google.com/search?h...earch
http://search.yahoo.com/search...UTF-8
Old Sep 27, 2007 | 04:16 PM
clean3two3's Avatar
so would a new clutch be better then getting the syncros repaired?
Old Sep 27, 2007 | 04:24 PM
yoohoo's Avatar
lol after all those replies you're still asking about the clutch?
Old Sep 28, 2007 | 08:58 PM
clean3two3's Avatar
Default Re: (yoohoo)
ok now my third is going out i usually shift around 3000 rpms now i have to shift above that so i am going to save up for a new clutch what would be a good clutch?
Old Sep 29, 2007 | 08:33 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: (clean3two3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean3two3 &raquo;</TD></TR><TR><TD CLASS="quote">ok now my third is going out i usually shift around 3000 rpms now i have to shift above that so i am going to save up for a new clutch what would be a good clutch?</TD></TR></TABLE>
Why are you saving up for a new clutch? If just 1 gear is out it is NOT your clutch.
Old Sep 29, 2007 | 09:18 AM
the cost of replacing synchros at a shop is pretty expensive... on average i was quoted 1200$ so i ended up just buying a type r tranny. in the meantime i learned about synchros and transmissions using the helms manual... then i repaired it with about 200$ total with all new synchronizers and one new bearing....
the cheapest quote ive ever gotten for a synchro replacement is 600$
Old Sep 29, 2007 | 09:26 AM
Duane_in_Japan's Avatar
Default Re: (LordAphotic)
You will have to do your own estimate shopping in your area, everywhere is different, I thought I just read yesturday here in HT somewhere that this guy paid less than $300, some shops may do bearings and other stuff because they garantee their work. You have to pull the tranny and the clutch is right there, look at it and make an informed decision if it needs replacing NOW or two years from now, you will have to pull the tranny to do it later. BUT you need syncros now.
Old Sep 29, 2007 | 10:05 AM
St Jimmy's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LordAphotic &raquo;</TD></TR><TR><TD CLASS="quote">the cost of replacing synchros at a shop is pretty expensive... on average i was quoted 1200$ so i ended up just buying a type r tranny. in the meantime i learned about synchros and transmissions using the helms manual... then i repaired it with about 200$ total with all new synchronizers and one new bearing....
or spend 40 bucks on syncromesh
Old Sep 29, 2007 | 03:38 PM
91redteg's Avatar
the grinding has nuthing to do with your clutch! it is the synchros
Old Sep 29, 2007 | 03:41 PM
COLIMA0003ITR's Avatar
sounda like syncros
Old Sep 29, 2007 | 04:02 PM
XSCIVIC93's Avatar
Default Re: (COLIMA0003ITR)
id use redline lightweight shockproof gear oil... fixed my grind instantly as well on my buddies prelude
Old Sep 30, 2007 | 01:24 AM
Default Re: (XSCIVIC93)
https://honda-tech.com/zero...55978
Thought I just saw it.
Old Sep 30, 2007 | 02:42 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by St Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
or spend 40 bucks on syncromesh</TD></TR></TABLE>
synchromesh will only fix a minor grind.... and its more of a bandaid than anything... it might fix the grind for a short while but the problem WILL come back... and it WILL be worse.
seriously... the best thing you could do is get a helms manual.... get the tools listed for the tranny... and replace them yourself.
U will learn a lot and have a skill you can use to make money if u ever need to.
Old Sep 30, 2007 | 03:10 AM
St Jimmy's Avatar
* B A N N E D *
At 16 i got my integra after about a month of beating on it hardcore the 3rd gear always would grind. Found GM Syncromesh put it in there and by the time i was 17 i went through 2 motors because I would beat the crap out of the car so bad, but the 3rd gear grind never came back...
Its cheap, its easy, and it works for a while
Or its more expensive, time consuming, it fixes it like new, you "learn" how to read a manual.
Old Sep 30, 2007 | 04:16 AM
fireman mike2288's Avatar
clean3two3 Can u read dude they told u about synchros and u asked asked about the clutch like 4 times if ur clutch is going out ull know, when shifting if the clutch wont release the gear for a period of time, Like in my old 1993 si delsol my clutch staretd to go out and when i would race i would shift in to third and it would just rev i had to to let og of the gas a few times then it would fully ingage the gear then u know ur clutch is going out and if u wanna buy a clutch ACT clutches are like 300 dollers or more dpepends on who u know or u can just get oem which will cost more but wow dude u sound kinda ummmm not fully there if u asked about clutches and we were talking about tranny things
Old Sep 30, 2007 | 07:54 AM
jdmjunkie8's Avatar
If you ask me I would say its probably the synchros, I had the same problem in my old DA except it grinded into 3rd.
