Squeaky windows
Old Sep 22, 2007 | 03:53 AM
SkyliteCustomz's Avatar
Default Squeaky windows
I have a 98 Integra sedan *Db7* and when i roll up the drivers side windows, it squeaks/screeches when its almost to the top. It doesnt squeak when its being rolled down though. Any ideas/suggestions? i searched but all i could find was stuff for DC's.
Old Sep 22, 2007 | 05:00 AM
g0tgot's Avatar
i got the same problem with my 99 dc2 hatch, the drivers side window, does not roll all the way to the top of the window, and it is skipping at the top on the track........dunno waht caused this, need to perform surgury to the door panels to get to the root of the prpblem....
Old Sep 22, 2007 | 09:32 AM
chevellion's Avatar
Default Re: (g0tgot)
i have a 96 db and i have the same occurance. driver and passenger side windows squeak when near the top. i'm thinking just the seals but idk.
Old Sep 22, 2007 | 03:24 PM
anyone else?
Old Sep 23, 2007 | 01:57 AM
TTT
Old Sep 23, 2007 | 03:15 PM
BUMP
Old Sep 23, 2007 | 05:14 PM
vtec8804's Avatar
* B A N N E D *
i remember my neighbor had this happening to his truck and used something that he just put on the line the window follows and squeak stopped ill try to talk to him and see what he used....
Old Sep 23, 2007 | 06:31 PM
vsmdc4teg's Avatar
http://www.team-integra.net/se...D=596
that should help you.
Old Sep 26, 2007 | 01:47 AM
thansk but i alread seen the article. im wondering if anyone ever had this problem with their DB7-8 and fixed it.
Old Sep 26, 2007 | 04:45 AM
Jackson123's Avatar
Default Re: (SkyliteCustomz)
Hey the same thing happens to my sunroof. or is this a simple lithium grease fix?
Modified by Jackson123 at 6:12 AM 9/26/2007
Old Sep 26, 2007 | 05:25 AM
jdmland's Avatar
Default Re: (Jackson123)
having the same problem in my 05 accord, but my windows are tinted, What can i do?
Old Sep 26, 2007 | 05:45 AM
VTEC_PRODUCTION's Avatar
Default Re: (jdmland)
use silicon lube. i have done this to so many vehicles and it works great...
Old Sep 26, 2007 | 09:28 AM
A's 94 GSR's Avatar
BG-33P
Default Re: (VTEC_PRODUCTION)
I WD-40'd my sunroof. No squeek/stick.
Old Sep 26, 2007 | 02:25 PM
i've tried wd-40..window still squeaks
Old Sep 26, 2007 | 04:14 PM
TTT
Old Sep 27, 2007 | 01:36 AM
HELP!..**** is getting annoying
Old Sep 27, 2007 | 01:45 AM
__oversea's Avatar
Default Re: Squeaky windows (SkyliteCustomz)
lol, mine does it too. both side
i think its the rubber trim around the window. i tried lube, no luck, makes window dirty.
it didnt make sound in summer, but starting to make sound again when its cold.
Old Sep 27, 2007 | 02:07 AM
yea it sucks..i know someone out there has a solution
Old Sep 29, 2007 | 03:54 AM
yes? no?
Old Sep 29, 2007 | 08:17 AM
roastbeefrichie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_PRODUCTION &raquo;</TD></TR><TR><TD CLASS="quote">use silicon lube. i have done this to so many vehicles and it works great...</TD></TR></TABLE>
get a can of silcone spray...lube up the window regulator (the rail which pushes the glass up & down). with your window down, spray the left & right sides (not the middle) generously. if it still squeals and squeals, you need to take your door panel off and get in there w/ the silicone spray
Old Sep 29, 2007 | 08:34 AM
CompanyFlow's Avatar
Default Re: (roastbeefrichie)
It really only takes about 30 minutes to get the door panel off and back on again
Old Sep 29, 2007 | 03:08 PM
30 minute to get the door panel off and back on again? wow..what kind of door panel do you have? lol but yea imma try the silicone spray..i'll let ya know how it works out
Old Sep 29, 2007 | 04:35 PM
Sean5826's Avatar
30 mins sounds about right, done it many times but id say 30 mins to take off and put back on the interior door card not the actual door panel, there is a difference
Old Sep 29, 2007 | 05:21 PM
MikeE07's Avatar
happens to me too i jus spay windex on the window and in side the tracks.it works for a while then it starts to sqeeak again
Old Sep 29, 2007 | 08:40 PM
Blahblah718293's Avatar
Default Re: (MikeE07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeE07 &raquo;</TD></TR><TR><TD CLASS="quote">happens to me too i jus spay windex on the window and in side the tracks.it works for a while then it starts to sqeeak again
lol windex cleans, not lubes.
i just spray every moving part wtih the silicone. and it works with the squeaking.
