check engine light (HELP)
Old Aug 16, 2008 | 05:17 PM
TegraD's Avatar
Default chack engine light (HELP)
my check engine light is on and i dont know why...
does anyone know how to read the ecu codes on a 97 integra...
i looked for the bliking light like in a crx but i dodnt see anything...
so if you could help that would be awsome!
Old Aug 16, 2008 | 06:10 PM
The G2 Racer's Avatar
Default Re: chack engine light (TegraD)
97 is ODB2.
Far as I know the only way to pull the codes is with a code reader.
Old Aug 16, 2008 | 07:02 PM
Dogginator's Avatar
Daisy... Daisy...
Read the FAQ. You need a paper clip to pull the codes.
This link:
https://honda-tech.com/zerothread?id=978933
Old Aug 16, 2008 | 07:05 PM
Dc4iNtEgRa's Avatar
Is Partying at your House
Default Re: chack engine light (The G2 Racer)
Edit: Dog beat me to it...
Its in the FAQ..
Under and behind the glove box to th right is a green rubber plug holder with two plugs in it. One has 3 wires, the other has two wires... Take the one with 2 wires, and put a paper clip or speaker wire to "JUMP" them. Then turn your key to AUX, and the CEL will blink the code or codes.
allmotorEG-SI
Jul 20, 2004 09:51 PM
99IntegraGS
May 3, 2004 07:18 AM
Simple
Nov 22, 2002 10:49 AM
johnzm
Sep 13, 2002 02:39 PM
