CEL Code 21...
Old Aug 22, 2008 | 08:04 AM
hondateg08's Avatar
Default CEL Code 21...
I got a CEL code 21 for my integra 92-93 which is the vtec solenoid. My engine is leaking where the vtec solenoid connects to the head. My question is "Would this be the cause of why the check engine light is on? because each time I go over 5000 rpm the CEL comes on. I check the wires and they are connected and good to go. I heard you could test to see if your vtec solenoid is working by connecting the vtec ground to the negative battery, is that true?
Old Aug 22, 2008 | 08:53 AM
SuzukaBlueAP2's Avatar
Default Re: CEL Code 21... (hondateg08)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondateg08 &raquo;</TD></TR><TR><TD CLASS="quote">My engine is leaking where the vtec solenoid connects to the head.</TD></TR></TABLE>
Seems to me this should be your first priority. Maybe it just needs a new gasket.
Fix the leak, clear the code and then see if it comes back.
Senbonzakura
Aug 27, 2006 01:16 AM
AdamQ3B85
Sep 9, 2005 04:10 AM
SOHC4life 96
36
Apr 3, 2005 08:39 AM
Hondasaurs
Apr 25, 2003 07:30 PM
Rhetoric
Jan 2, 2002 01:10 AM
