Transmission Help
Old Aug 16, 2008 | 05:56 PM
nitericer85's Avatar
Default Transmission Help
Hey guys umm i bought a 92 integra from a friend recently and he put a vtec engine from probably a 96 integra and wat ive noticed is the car shifts perfect all the way into 5th but get real high rpms at 60mph at probably more than 4000rpm should i get a transmission from the 96 vtec because the car is a 92 or the transmission is right but needs a clutch kit appreciate the help guys!!
Old Aug 16, 2008 | 07:03 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Transmission Help (nitericer85)
Are you sure that the gauges are calibrated properly. Aftermarket gauge faces affect this.
Old Aug 18, 2008 | 04:00 PM
Default Re: Transmission Help (Dogginator)
well lets see umm its not aftermarket but the rpm gauge in the dash isnt working could this be connected with me getting high r's while im just cruising in 5th?
Old Aug 18, 2008 | 05:43 PM
Dogginator's Avatar
Daisy... Daisy...
You are leaving out a lot of hidden details. Are you sure the speedometer even works correctly?
Old Aug 18, 2008 | 06:58 PM
oh ok i see what you say yeah its funny i noticed it was climbing a bit slow well im going to get that replaced soon so il get back with results.
Old Aug 18, 2008 | 07:04 PM
ivan93egreppin210's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitericer85 &raquo;</TD></TR><TR><TD CLASS="quote"> should i get a transmission from the 96 vtec because the car is a 92 or the transmission is right but needs a clutch kit appreciate the help guys!!</TD></TR></TABLE> no. it wont work without some sort of conversion vit. 96 tranny is hydro and 92 is cable. if anything get a b16 cable tranny. does it rev fast? you might already have one.
Old Aug 18, 2008 | 08:10 PM
The Clash's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitericer85 &raquo;</TD></TR><TR><TD CLASS="quote">the car shifts perfect all the way into 5th but get real high rpms at 60mph at probably more than 4000rpm</TD></TR></TABLE>
If the tach/speedo is working correctly and you are running 4K at 60mph, chances are you have a 92-93 GSR cable tranny or more probable a JDM B16A cable tranny. The stock LS tranny would be pushing around 4K at 80mph.
Blue Papaya
20
May 19, 2007 05:22 PM
ryanjusmc
Sep 24, 2006 04:40 PM
YellowPhoenix095
Sep 8, 2006 04:04 PM
Sarren
Aug 10, 2004 08:51 PM
