Driveability problems after OBD1 conversion <---------HELP!
Old Aug 19, 2008 | 06:51 PM
vietnamezerice's Avatar
Default Driveability problems after OBD1 conversion <---------HELP!
I have a 98 DB7 that I converted to manual... it runs fine with a stock P75 but when I plug my chipped p28 in the car, the idle is low and jumpy and the car will not accelerate and will just bog down. I tested the P28 in my brother's 98 EK (LS swap) and it runs fine. I have no clue where to start diagnosing the problem...
Old Aug 19, 2008 | 10:18 PM
Default Re: Driveability problems after OBD1 conversion <---------HELP! (vietnamezerice)
anyone have the same problem?
Old Aug 20, 2008 | 02:18 PM
bump
Old Aug 20, 2008 | 09:54 PM
i searched already! i still can't find any solutions
Old Aug 21, 2008 | 09:49 AM
hondaman1212's Avatar
is the p75 a manual ecu..the problem must lie within the auto to manual swap.check back over everything and try to. im kinda confused it said you did a manual conversion and a obd1 upgrade but what kind of car do you have?it would have to be a 90 to 93 da to convert to obd1 and if the ecu was out of a 98 then it would be obd2 i dont know your post is a little confusing but im sure i can help
Old Aug 21, 2008 | 03:09 PM
Default Re: Driveability problems after OBD1 conversion <---------HELP! (hondaman1212)
I have a 1998 Integra (OBD2) and I used a OBD1 jumper harness with a chipped p28.... does that make things clearer?
Old Aug 21, 2008 | 09:02 PM
SkyliteCustomz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietnamezerice &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1998 Integra (OBD2) and I used a OBD1 jumper harness with a chipped p28.... does that make things clearer? </TD></TR></TABLE>
what motor do u have?
Old Aug 21, 2008 | 11:17 PM
Default Re: Driveability problems after OBD1 conversion <---------HELP! (SkyliteCustomz)
an LS (B18B1) from a 99
Old Aug 22, 2008 | 03:37 AM
..so why would you use a chipped p28?
Old Aug 22, 2008 | 06:09 AM
Default Re: (SkyliteCustomz)
the p28 has a LS base map... right now i have a check engine light because my seconary O2 sensor is bad... so that's part of the reason I want to use the P28
Old Aug 22, 2008 | 09:50 PM
Default Re: (vietnamezerice)
anyone else?
Old Aug 23, 2008 | 07:53 PM
Old Jul 17, 2009 | 03:46 PM
mattma's Avatar
New User
I am having the same problem.... i swapped in a JDM B18B, and ran a USDM OBD2 ECU, ran fine except baro code and WOT issue where it bogs, so i bought a chipped p06 and OBD1 conversion harness... hooked it all up and it idles ok, but when the car moves, even coasting the revs bounce up and down and i'm unable to accelerate... putting the OBd2 Ecu back in returns my normal ecu behaviour.. any idea's?
vietnamezerice
Aug 20, 2008 09:54 PM
Paul99EX
Aug 10, 2005 11:39 AM
jdmteg01
Aug 19, 2004 09:42 PM
salbaje
Dec 9, 2002 01:39 PM
salbaje
Feb 18, 2002 12:01 AM
