Ls Vtec Or B16a?
Old Aug 21, 2008 | 02:31 PM
92hondaswap's Avatar
Default Ls Vtec Or B16a?
Hi I have a 92 honda civic hatch with a B18a1 engine in it. I like to make it Ls Vtec but I also have a B16a complete engine and I'm not sure if I should do the Ls Vtec or put in the B16a instead.. what can I make the most power out of?? any suggestions???
Old Aug 21, 2008 | 02:44 PM
Kendall's Avatar
Default Re: Ls Vtec Or B16a? (92hondaswap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hondaswap &raquo;</TD></TR><TR><TD CLASS="quote">what can I make the most power out of?</TD></TR></TABLE>
You can most certainly make more power out of an LSV than out of a B16A.
You need to figure out what exact components you plan on using for the LSV should you go that route.
Old Aug 21, 2008 | 05:22 PM
HONDRETTI's Avatar
Default Re: Ls Vtec Or B16a? (Kendall)
if you would rather go lsv then you have all the components you need. rebuild the bottom end of your ls with your b16 pistons, swap the b16 head on with a golden eagle kit, convert your vtec compenents, upgrade your cam gears, intake manifold, add some injectors and youre good to go.
but i would just simply swap in the b16, boost it, and call it a day.
Old Aug 21, 2008 | 05:23 PM
Kendall's Avatar
Default Re: Ls Vtec Or B16a? (HONDRETTI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDRETTI &raquo;</TD></TR><TR><TD CLASS="quote">if you would rather go lsv then you have all the components you need. rebuild the bottom end of your ls with your b16 pistons, swap the b16 head on with a golden eagle kit, convert your vtec compenents, upgrade your cam gears, intake manifold, add some injectors and youre good to go.</TD></TR></TABLE>
Don't forget about the rod bolts.
Old Aug 21, 2008 | 05:31 PM
HONDRETTI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">
Don't forget about the rod bolts. </TD></TR></TABLE>
yes, and rod bolts. ITS THE MOST IMPORTANT PART. lol
Old Aug 21, 2008 | 05:47 PM
95dc2teg's Avatar
but i would just simply swap in the b16, boost it, and call it a day.</TD></TR></TABLE>
same here
Old Aug 21, 2008 | 06:04 PM
Kendall's Avatar
To be perfectly honest, I'd just throw in the B16 as well. Sometimes simplicity wins on principle.
Old Aug 21, 2008 | 06:11 PM
dadriver's Avatar
Default Re: Ls Vtec Or B16a? (95dc2teg)
i seen ls bottom end with b16 head with some boost go 11.90 in 1/4 that would prob be that best haha that would in a eg
Old Aug 21, 2008 | 08:48 PM
ReDJdMBuB's Avatar
if u planning on doing all motor i would go lsv but i seen videos of boosted b16s clean up saleens ((cant believe everythin u watch but u kno...))
Old Aug 23, 2008 | 04:21 PM
Ok OK!! I've decided based on your feedback to just drop the B16a in it and call it a Day,lol Now I friend told me I can only do 10-12 PSI with stock pistons.. Now Is it possible to use LS Pistons with B16a connecting rods instead of using B16 pistons to get higher PSI's..??? If I have to Bore the block for that then I rather keep it with its stock pistons...
desii
17
Jan 25, 2008 10:36 AM
Jaydo
Jul 10, 2003 04:19 AM
khcivic
May 4, 2003 06:40 PM
ridnmyhonda
May 16, 2002 04:59 PM
