Fixing Windshield Leak
Old Aug 20, 2008 | 07:49 AM
Louse76's Avatar
Default Fixing Windshield Leak
So I've had my '94 Integra since 2002.
Recently, it's developed a leak that causes a drip in the driver's footwell.
I assume this is probably a problem with seals around the windshield - is that right? Is this a common problem?
Thanks!
Old Aug 20, 2008 | 01:14 PM
uses0ap's Avatar
Default Re: Fixing Windshield Leak (Louse76)
i have a leak on the passenger side that leaked through (behind the glove box to teh floor)...the leak was from the windshield molding from where the corner of the hood is (a black plastic strip across)..to fix it i just put a piece of black tape across...cant really tell its there unless u really look at it..but it works
Old Aug 20, 2008 | 06:19 PM
ProjectDohc's Avatar
New User
This was a write up for Da6 Integra but the same thing applies basically
http://nzintegra.com/footwell.html
Old Jun 30, 2009 | 01:48 PM
em1si's Avatar
i know this is an old thread...but definetly helped out....
Old Jun 30, 2009 | 05:52 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
94-01 Integras DO NOT have the same seals under the cowl that DA Integras have. So unfortunately if you have a leak, it's not as easy to fix as it is on DA Integras.
My car has water getting in under the cowl and dripping down behind the ECU, but the place it's coming in is actually inside the front right frame rail, so there will be cutting and welding required to even access the location where the water is coming in.
jumpin4abeat
Jul 20, 2011 06:18 PM
JDM_is_overrated
Oct 13, 2008 12:42 PM
Black EH6
Apr 18, 2007 04:15 PM
uses0ap
Oct 1, 2006 11:24 AM
ATS*VEEE
Dec 19, 2005 11:39 AM
