Need Help.
Old Aug 20, 2008 | 08:40 AM
r1chst3r's Avatar
Default Need Help.
ok well i purchased a 94 gsr shell and when i drop in my motor and everything the last thing i did was put in the shift linkage but seems like im missing something for it seems like its a pin/bolt that i need for the actual shifter well thnx in advance and here is a pic of what im talking about hopefully i can get some help :D
Old Aug 20, 2008 | 09:00 AM
r1chst3r's Avatar
Default Re: Need Help. (r1chst3r)
anybody? i tried putting a bolt and but but before i got to crank the engine i tested to see if it shift right and only went to 1st 2nd and 5th gear so i was like there is something wrong and i think its bc of the pin that goes there
r1chst3r's Avatar
but im not to sure if im right or not
Old Aug 20, 2008 | 09:47 AM
neardon's Avatar
I'm a Jackass
http://www.acuraautomotivepart...ormal
You need what we in the honda world call a "bitch pin"
Old Aug 20, 2008 | 09:51 AM
r1chst3r's Avatar
Default Re: Need Help. (neardon)
i see i knew it was a pin well i have a 97 civic ex wrecked can i just use the one that one has ?
Old Aug 20, 2008 | 10:02 AM
Circusraven's Avatar
It's commonly refered to as the "bitch pin" Look on page 8 my build thread (link is below) you'll see what it looks like, as well as the tool to install it and remove it.
I'd say just go buy a new one at the dealership, it probably costs a dollar. There is also a clip that goes around the hole the pin goes into, just in case it ever decides to start slipping out (which if you've ever tried taking one off, you'd think it's impossible).
Old Aug 20, 2008 | 10:09 AM
Default Re: Need Help. (Circusraven)
Oh yeah, forgot to mention. You can use the pin off teh civic's linkage, they are the same.
Old Aug 20, 2008 | 03:39 PM
steveo135's Avatar
yea that thing is a bitch pin... after reading about it and trying for about a half hour to remove it during my rebuild i just left it attached to the tranny, unbolted it from the shifter and pulled the engine\trans with it still attached and dropped the engine\trans without taking that pin out lol
DC2_Legend
Transmission & Drivetrain
May 23, 2011 12:50 PM
Dice21
Oct 2, 2005 02:11 PM
Black_SiR
Oct 26, 2004 03:24 PM
cxSHOE
Nov 16, 2003 08:13 AM
allmotorls95
Sep 10, 2002 09:00 AM
