oil leak problem!!
oil leak problem!!
well guys i got a leak between the block n tranmission soo i change the rear main seal well it still leaking from the same spot...and also change the oil pan gasket also the longblock is clean no oil leak from anywhere but where the block n trannmission meet.. soo idk what it is soo guys any problems like mines or any advance or help plzzz guys
Re: oil leak problem!! (mistik_DC4)
man we both on the same page (mistik dc4) i change the seal put back the tranny turn thr bitch on still leak i dont kno man
Re: oil leak problem!! (dc2beast978)
When you replaced the rear main seal, did you measure how far the original seal was protruding from the housing before you removed it, and did you make sure you pressed the new seal in the same amount as the original seal?
How did you press the new seal in?
yes did everything correct the seal went in tight fit perfect the thing is when i took of the tranny again the main seal wasent moist or wet it was good but still leak from there
LSVTEC 91 Civic
04-26-2005 04:23 AM
B16CRXT
05-12-2004 11:58 AM
