Help - Need Possible Solutions
Old Oct 9, 2008 | 04:22 AM
Bo0steDC4's Avatar
Default Help - Need Possible Solutions
We just dropped in another b18b1 motor into my dc4. We pretty much blew the other motor. But anyways, it wont start up. We checked all the wiring, harnesses, fuel lines and whatever else we could think of. the motor would crank but wont start. we tested the spark plug wires and they all arc when we tested them. so i can't be the ignition right? we tested the injectors, to see if they sprayed out fuel and they do. the spark plugs are new, so it can't be the spark plugs. there is gas in the car, so i don't think its the fuel. Anybody got any ideas on what could possibly be wrong? Any input towards fixing the car is much appreciated.
Old Oct 9, 2008 | 05:22 AM
slaminsam's Avatar
Default Re: Help - Need Possible Solutions (Bo0steDC4)
Check to make sure you didnt cross the map sensor with the tps. Then I would check the timing to make sure the belt hasnt jumped.
Old Oct 9, 2008 | 06:23 AM
AWD Terror's Avatar
Default Re: Help - Need Possible Solutions (slaminsam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slaminsam &raquo;</TD></TR><TR><TD CLASS="quote">Check to make sure you didnt cross the map sensor with the tps. Then I would check the timing to make sure the belt hasnt jumped.</TD></TR></TABLE>
My thoughts exactly.
I switched the tps and map sensor and missed my dyno day b/c I couldn't get it to start.
Old Oct 9, 2008 | 09:11 AM
bakertime's Avatar
Double check that your plug wires are on the right plugs...if they're getting spark, it could be that it's just not at the right time.
Old Oct 10, 2008 | 10:08 AM
Bo0steDC4's Avatar
Okay I'll try doing these check ups today.
Old Oct 10, 2008 | 02:31 PM
God-Driven's Avatar
check the timing marks and do a compression test, do you know if the motor was running right before you got it?
jayeghatch
Mar 23, 2012 06:32 AM
milanoteg
Sep 12, 2009 08:35 PM
97civic07gsxr
19
Feb 24, 2009 05:20 PM
I3ackfire
22
May 14, 2004 09:50 AM
