Rebuilt engine throwing code 3 and 5
Old Oct 13, 2008 | 10:21 AM
95_red_dc's Avatar
Default Rebuilt engine throwing code 3 and 5
I just rebuilt my b18c1 and I'm trowing a check engine light which the Haynes manual say its the manifold absolute pressure. It goes back off when you shut the car off and on and it take a little it for it to come back on. It seems to idle good and smooth. The book says check the map sensor. What could it be I did not a have this problem before the rebuilt motor. It also seems like I am getting bad gas mileage.
Old Oct 13, 2008 | 10:30 AM
HONDRETTI's Avatar
Default Re: Rebuilt engine throwing code 3 and 5 (95_red_dc)
double check your lines
Old Oct 13, 2008 | 10:31 AM
95_red_dc's Avatar
Default Re: Rebuilt engine throwing code 3 and 5 (HONDRETTI)
I checked and everything looks fine
Old Oct 13, 2008 | 10:49 AM
95_red_dc's Avatar
There is this piece that I broke that's on top of the intake manifold which is the VALVE ASSY., PURGE CUT SOLENOID. The piece on top of it FILTER ASSY., SOLENOID VALVE is what broke off. Here is a diagram of it numbers 6 and 8. http://www.acuraautomotivepart...ormal Could that have anything to do with the check engine light?
Old Oct 13, 2008 | 03:40 PM
95_red_dc's Avatar
help
jillian6700
Dec 12, 2009 04:41 PM
95_red_dc
Oct 17, 2008 08:22 PM
1998_4dr_gsr
Oct 27, 2006 03:21 PM
Jdmb18EF
Jan 17, 2006 05:34 AM
DannyITR
Jul 21, 2004 05:10 PM
