obd2a and obd1 engine dizzy help
Old Oct 9, 2008 | 10:35 AM
pmey's Avatar
Default obd2a and obd1 engine dizzy help
OK so i just go done with my b20V a couple week ago every thing is find but my IDLE is Weird when you start it it idle at 800-900 the it drop it 300 to 500 constinly back and fourth, where the motor kind of shake and sputter so to make it quick my car is 96 obd2a and im using a obd2a to obd1 conversion harrness running a chipped p28 tuned based on my b20V spec. But my engine dizzy is acuttly and obd1 dizzy plug into a obd2a is this what is affecting it?
I have no check engine light the car run super good when i drive. only when im stop and idleing drop
that where my problem is.
Old Oct 9, 2008 | 11:38 AM
gonmaro's Avatar
Default Re: obd2a and obd1 engine dizzy help (pmey)
check for vacuum leaks and Idle control valve. im pretty sure it have nothing to do with the dizzy
Old Oct 9, 2008 | 12:35 PM
pmey's Avatar
Default Re: obd2a and obd1 engine dizzy help (gonmaro)
check that but still the same no leak
Old Oct 9, 2008 | 11:13 PM
DC2_foo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gonmaro &raquo;</TD></TR><TR><TD CLASS="quote">check for vacuum leaks and Idle control valve. im pretty sure it have nothing to do with the dizzy</TD></TR></TABLE>
that's the only thing i could think of also that would cause the idle to act like that...you should double check it...
Old Oct 10, 2008 | 06:45 AM
AWD Terror's Avatar
Default Re: obd2a and obd1 engine dizzy help (DC2_foo)
Op: does the car do this as soon as you start up? Or does it go through the "warm up" phase first?
Old Oct 15, 2008 | 03:54 PM
DC2_foo's Avatar
Default Re: obd2a and obd1 engine dizzy help (AWD Terror)
figure out what was wrong with the car yet?
Old Oct 15, 2008 | 09:18 PM
vietnamezerice's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2_foo &raquo;</TD></TR><TR><TD CLASS="quote">figure out what was wrong with the car yet?</TD></TR></TABLE>
x2
dohc4life
Apr 7, 2011 04:22 AM
pmey
Oct 10, 2008 07:53 AM
gslice14
Dec 5, 2006 11:58 AM
VRD^don
Jun 6, 2006 11:12 AM
cashman38
Dec 11, 2005 06:52 PM
