iacv question
Old Oct 8, 2008 | 03:54 PM
josh352727's Avatar
Default iacv question
I have obd2 (98) gsr motor running on a obd1 p72 and need a new iac valve. My question is can I use any year iac valve off any b series, for example 90 b18 iacv?
Just wondering because there is always a da or two at the junkyard.
Please help if you know, thanks.
Old Oct 8, 2008 | 06:15 PM
vietnamezerice's Avatar
Default Re: iacv question (josh352727)
it should work as long as the bolt holes match up and the plug for it matches up... make sure it's a 2 wire IACV whereever you're pulling it from
Old Oct 8, 2008 | 06:19 PM
JoshEK4's Avatar
Default Re: iacv question (vietnamezerice)
there are 2 obviously different iac valve that honda used, the only difference is the bolt pattern, you will be able to tell the difference easily
Old Oct 8, 2008 | 06:20 PM
Default Re: iacv question (JoshEK4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoshEK4 &raquo;</TD></TR><TR><TD CLASS="quote">there are 2 obviously different iac valve that honda used, the only difference is the bolt pattern, you will be able to tell the difference easily</TD></TR></TABLE>
for integra's of course
Old Oct 8, 2008 | 07:13 PM
josh352727's Avatar
Thanks guys, so basically they all work the same obd0 to obd2? (as long as its same style bolt wise)
Old Oct 8, 2008 | 07:18 PM
yeah, the plug should also fit too
Old Oct 8, 2008 | 07:23 PM
josh352727's Avatar
Looking them up on http://www.acuraautomotiveparts.org the obd0 will not work (differ bolt pattern), but the obd1 and obd2 look the same but have different part #'s.
Old Oct 8, 2008 | 07:41 PM
the OBD2 ones serve more than one purpose vs the OBD1 ones
Old Oct 9, 2008 | 01:24 PM
FOMULA91's Avatar
I'm using the OBD0 on my OBD1 motor but not sure about the OBDII...
Old Oct 9, 2008 | 01:35 PM
Default Re: iacv question (FOMULA91)
only one way to find out
dc2lee
Mar 3, 2017 10:14 PM
IHEARTMYHONDA91
Nov 13, 2009 09:27 PM
spoon93
Dec 11, 2007 08:06 PM
ApolloSpeed
Sep 12, 2005 04:58 PM
D16SohcVtec
14
Oct 15, 2004 08:42 AM
