car leaks
Old Oct 11, 2008 | 09:00 AM
JDM_is_overrated's Avatar
Default car leaks
so heres the problem, when it rains, the floor on the passenger side gets wet. that could be really a problem in washington
any ideas what could be wrong?
Old Oct 11, 2008 | 12:36 PM
kronikSLOW's Avatar
Default Re: car leaks (JDM_is_overrated)
hmm lets use our brain. THERE IS OBVIOUSLY A HOLE SOMEWHERE OR A BAD GASKET SOMEWHERE. OPEN YOUR EYES AND LOOK. pour water on your car and see what you find. not rocket science its a basic leak wow. close this thread.
Old Oct 13, 2008 | 09:58 AM
Default Re: car leaks (kronikSLOW)
very helpful. thanks
Old Oct 13, 2008 | 11:20 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Right now we have no idea what car you have, and that can make a big difference as to what the culprit might be.
DA Integras are notorious for certain seals under the windshield deteriorating, causing leaks. It's a fairly cheap and easy fix.
3rd gen Integras do not have these seals. I have had problems with water leaking onto the passenger side floor for years, along with several other people having leaks in the same place, and that is caused more because of seam seal deterioration or possibly metal corrosion. The problem is that the area is inside a welded frame rail. The only way to access the area is to drill out spot welds have then have them welded back up.
Old Oct 13, 2008 | 12:42 PM
ilvi3tkidxx's Avatar
id check all seals.. but yea pour water and c where its coming from
hbracer93
41
Apr 6, 2022 05:04 AM
JDMx05
Sep 10, 2011 08:02 PM
oMek
Oct 30, 2006 01:20 PM
LowTEC SaiMike
Dec 3, 2005 08:12 AM
ahunt01
Nov 20, 2003 06:05 AM
