tps sensor?
Old Oct 13, 2008 | 01:20 PM
MyEfSi2Slow's Avatar
Default tps sensor?
ive read up on a little bit of this, all i can get is that you have to replace the whole throttle body, i drive a b18a1 90 teg and im just tryin to replace the sensor, is there a certain way that you have to put it back on? or do i just put it on and im good to go
Old Oct 13, 2008 | 01:54 PM
BoSox46GSr's Avatar
Default Re: tps sensor? (MyEfSi2Slow)
I believe it must be calibrated.
Old Oct 13, 2008 | 01:56 PM
Kendall's Avatar
Several companies offer replacement sensors that are a direct replacement for the original. The other option is to go junkyard hunting and pick up one.
The "headless screws" come loose with a set of pliers and you can use your fingers to get the out the rest of the way. Or you can cut a groove into the top of them and get them out with a flathead screwdriver. Make sure you adjust the new TPS properly after installation.
Old Oct 14, 2008 | 04:17 PM
when i bought the car none of this stuff was happening, and i just found out that my tps sensor is a replacement one, so i dont know what else could be wrong, sometimes my car drives fine sometimes it runs like shiet, ill figure it out somehow
Old Oct 14, 2008 | 04:33 PM
HONDRETTI's Avatar
CEL? code 7?
Old Oct 14, 2008 | 08:52 PM
vietnamezerice's Avatar
Default Re: tps sensor? (HONDRETTI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoSox46GSr &raquo;</TD></TR><TR><TD CLASS="quote">I believe it must be calibrated.</TD></TR></TABLE>
it does.. search on YouTube, there's a TPS install on a Skunk2 throttle body How-to video
cryingsuns
Mar 20, 2011 01:13 PM
shutta
Apr 5, 2007 04:46 AM
ActiveAero
Aug 15, 2003 07:40 PM
