engine torque dampes?
hey guys, i was just curious about these. are they worth putting on, how hard is it to install, where exactly do they go? any input would be much appreciated.
I assume this is what you are referring to?
http://jhpusa.com/store/pc/vie...=1701
It's mounts on the driver side at the shock tower to the engine mount iirc.
From what I've heard there not bad. It's supposed to reduce wheel hop, as well as keep your motor from shifting and vibrating around putting un needed stress on exhaust components, etc. I plan on putting one on my car this winter during my build.
Sorry, I looked for a pic with one installed but couldn't find it.
sick, thanks guys. so if i were to use them i would be using two? one for each side right?...and im guessing some hasport replacement motor mounts would be even better for stability.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moosta936 »</TD></TR><TR><TD CLASS="quote">sick, thanks guys. so if i were to use them i would be using two? one for each side right?...and im guessing some hasport replacement motor mounts would be even better for stability.</TD></TR></TABLE>
Replacement motor mounts will give the best results, Hasport is a great option. I wouldn't waste money on those torque mounts.
no one on the driverside only.
BojeEM2
Honda Civic (2001 - 2005)
Mar 29, 2007 09:09 AM
Mad Money
19
Mar 24, 2006 06:08 PM
