ignition problem,i think
Old Oct 11, 2008 | 03:11 PM
redrim's Avatar
Default ignition problem,i think
car specs
01 gsr teg
basically stock-i/h/e
70,000miles
drove to canada one day to go to the strip club and party legally,got there no problem.
car sat in drive way for a couple hours,go out to leave and the car wont start.tunr the key all the way and no lights go on!.i turned the headlights on and everything lit up.it just doesnt fire/crank/make a sound.pop the hood,and everything looks normal.check the fuses and everything is good except the 40a ig (ignition fuse i think).so we say whatever and get a different ride out.this morning we go out to change the fuse,it goes in.i connect the ground to the battery and then we try and start it again.the fuse blows again.tryd it again.fuse blows again.nothing.
the teg has no wire tuck,stock motor and nothing to mess with electrical wise.
thanks
Old Oct 12, 2008 | 10:32 AM
redrim's Avatar
Default Re: ignition problem,i think (redrim)
bump,anyone
Old Oct 12, 2008 | 07:38 PM
redrim's Avatar
took everything ingnition wise off and put it back together and its runs,just cant get the [freak]ing key out,its stuck??????????
Old Oct 12, 2008 | 11:14 PM
vietnamezerice's Avatar
maybe there's a short somewhere... that's probably why the fuse keeps blowing... was your car an automatic before? if it was, that's probably why you can't take the key out
Old Oct 13, 2008 | 06:36 AM
AWD Terror's Avatar
Default Re: ignition problem,i think (vietnamezerice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redrim &raquo;</TD></TR><TR><TD CLASS="quote">took everything ingnition wise off and put it back together and its runs,just cant get the [freak]ing key out,its stuck??????????</TD></TR></TABLE>
Had this problem in one of my old beaters. Never did get it out, just spray painted it black so you couldn't see it.
91sedan_kid
Jan 19, 2025 09:13 PM
Dc295kid
Jan 1, 2011 04:47 PM
Integra2Xtreme
Aug 3, 2008 11:46 AM
MeanGreenEG9
May 6, 2003 05:02 AM
